Imap settings when outlook PST larger than server capacity
shivy
I have the following situation:
Have a pop3 email on a server (domain host server) with a capacity of 2GB.
At the moment the outlook wipes the emails on the server older than 15 days.
The outlook PST file is now at 19GB.
I want to use this account as IMAP to be able to use from another PC at the same time or when away from home.
I understand that on my windows mobile phone I can set the IMAP account to donwload only the last 3 days of emails and sync them after i read them and file them.
Now this is the thing I would like to do on my server, use the Outlook 2007 with IMAP settings similar to my WM6 phone.
The server cannot host more than 2GB. Any ideas, please ?
If you hit 2GB fairly quickly, use IMAP on computer #2 and keep POP3 on #1, setting the delete after xx says to a higher number (100 days is the max)... and archive the 19 GB pst (if you are worried about the size). This lets you have new mail on the other computer and keeps the server under quota. Note that when messages are deleted from the server, they'll disappear from computer #2 on its next sync.
If you want to use IMAP on both computers, remove the pop account, create an imap account. The IMAP account will create its own data store. The 19 GB local pst will remain local - anything in it that isn't on the server that you want on the other computer will need to be dragged to the imap data store. As you near the 2GB limit, drag messages to either the 19 GB pst you use now or to a new pst.
Outlook doesn't support downloading the last 3 days using imap - its all or nothing.
A stop Outlook 2010 from downloading email with IMAP settings Using Outlook 1
A MS Outlook 2007 and AOL connectivity issue (IMAP settings) Using Outlook 2
V Scheduled backup of imap account Using Outlook 7
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
I IMAP - are emails dynamically fetched from server as required? Using Outlook 2
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
CWM030 Archiving ON the imap server Using Outlook 3
Y Outlook not displaying all imap emails Using Outlook 5
Y IMAP errors with Outlook 2016 Using Outlook 2
Z Can't delete IMAP folder Using Outlook 2
GaryW88 2016 Archiving IMAP keeping mail on Gmail Server Using Outlook 1
M cannot change delivery folders with IMAP accounts Using Outlook 0
E 365 Outlook changed from POP3 to IMAP,all contacts lost Using Outlook 3
O POP3 vs iMAP? Using Outlook 1
B How to 'really' delete IMAP emails? Using Outlook 6
K IMAP Server Wants to alert you to the following: cannpt rename system folder Using Outlook 1
Diane Poremsky Setting up an Outlook.com IMAP account New Slipstick.com Articles 0
M 10 Imap gmail accounts into OL2016-32b want 1 calendar Using Outlook 3
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
L Gmail POP, Android IMAP, Outlook 2013 setup close Using Outlook 5
B IMAP folders don't update when Outlook 365 opens Using Outlook 0
J IMAP server Using Outlook 0
J Converted .ost to .pst: Want to Import and Reconnect with IMAP Email Account Using Outlook 2
GregS Import from Outlook.com .ost to IMAP .pst? Using Outlook 3
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
I Outlook 2016 and Slow access to Outlook.com IMAP Using Outlook 0
E POP vs IMAP on iDevices Using Outlook 3
Mark Foley Where are Outlook categories save for IMAP? Using Outlook 12
P Newly created IMAP subfolders not showing up on email clients away from computer. Using Outlook 3
M Cannot Delete Emails from IMAP inbox Using Outlook 4
Mark Foley Outlook prompts for IMAP user/PW when domain PW changes Using Outlook 0
