Print Macro with Page Range?
I would like to write a very simple macro to print only the first page of an email. It would seem to me that I could just insert something like:
obj.PrintOut From:=1, To:=1, Copies:=1 (Taken From Excell Macro)
OR
obj.PrintOut FileName:="", Range:=wdPrintRangeOfPages, Item:= _
wdPrintDocumentContent, Copies:=1, Pages:="1", PageType:=wdPrintAllPages, _
ManualDuplexPrint:=False, Collate:=True, Background:=True, PrintToFile:= _
False, PrintZoomColumn:=0, PrintZoomRow:=0, PrintZoomPaperWidth:=0, _
PrintZoomPaperHeight:=0 (Taken From Word Macro)
into the OTM macro below, I have tried both with minimal tweaking and have had no success. As it is now possible to do File>Print>Print Range it seems that a macro could be written to preform this function. Assistnace with the proper code would be awesome.
If this is not possible, is there a way to work around this? For example a macro that would make a plain text copy, print one page, then delete the plain text copy. Maybe something that would open it in a browser print one page and then close it. Again, any help would be awesome!
Public Sub PrintMail()
Dim obj As Object
Set obj = Application.ActiveExplorer.Selection(1)
obj.Display
obj.PrintOut
Forum Admin
BTW, one Outlook developer MVP suggested sendkeys - not elegant, but can get the job done.
Sub PrintOnePage()
   SendKeys "%F", False
   SendKeys "P"
   SendKeys "{TAB 2}", True
   SendKeys "{DOWN}", True
   SendKeys "1"
   SendKeys "{ENTER}"
(Those are the send keys for 2007.)
manitou13
Slipstick & Detr0itkid,
Good info thus far in this thread. I have a question for you two.
Essentially, I would like to have one specific folder (for example, "print_folder") in my tree to automatically print the first page on any e-mail messages in this folder that is a new message. I already have a rule set where specific e-mail messages are directed to the print_folder. But I would like to see all new mail that is dropped in print_folder automatically the first page is printed in each message.
Any thoughts?
-Eric
if you want to print it as you move the mail, try a rule that runs a script (the link to the macro Detr0itkid posted) then moves the mail. Because its a full macro and not a script, you might need to call it with a script. I'm not sure if the delay Det0itkid mentions will affect the ability of the rule to work correctly. (I have not tested it.)
manitou13
It would be awesome since the mail is automatically moved to a specific folder (print_folder) that it also will automatically print the first page once the mail arrives to the folder...
Thanks! :)
-Eric
I hven't tested that macro with a rule, but it might work.
S Macro to print & move selected emails? Using Outlook 3
P Possible to write a macro to print all attachments with specific . Outlook VBA and Custom Forms 1
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
M Batch print without appended trail of repeated e Using Outlook 2
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
A Day view - print appointment details Calendar Printing Assistant 1
I print calendar without subject and details Using Outlook 1
oliv- property "is printed" or catching print events Outlook VBA and Custom Forms 2
Diane Poremsky Print a list of your Outlook folders New Slipstick.com Articles 0
Diane Poremsky Combine and Print Multiple Outlook Calendars New Slipstick.com Articles 0
B Print list of previously sent recipients Using Outlook 1
R Print email message and attachment in order Outlook VBA and Custom Forms 2
A Print first page of a new email Outlook VBA and Custom Forms 7
Diane Poremsky Print Monthly or Work Week Calendars New Slipstick.com Articles 0
Diane Poremsky No drop down calendars in Outlook 2010 Print Options New Slipstick.com Articles 0
J Auto print PDF attachments as they arrive with certain words in subject Outlook VBA and Custom Forms 3
G Calendar monthly view - Print just 3 weeks Calendar Printing Assistant 5
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
M Print Attachments from another mailbox (not default) Outlook VBA and Custom Forms 2
L Outlook 2010 Quick Print Attachment, nothing happend Using Outlook 0
C automatically print attachments Using Outlook 4
J Automatically Print PDF When They Are Received Using Outlook 4
M button to send and print emails Using Outlook 26
S How to print ONLY first line of appointments in month view? Using Outlook 1
M print free/busy schedule of an user Using Outlook 2
O For Outlook 2007 - VBA to print attachments Using Outlook 1
W Cannot print Outlook 2007 emails Using Outlook 2
R problem with incomming e-mail I am unable to print full e-mail letter Using Outlook 1
M Custom print contacts Using Outlook 2
E Can't print from Outlook on wifi network Using Outlook 0
E can't print some retail discount coupons Using Outlook 7
J calendar print setup in outlook 2010 Calendar Printing Assistant 1
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
D Use Outlook 2003 embedded imaged cannot print from the mail preview list Using Outlook 4
J Print next 7 days view of calendar (2010) Using Outlook 3
C Print all emails in a single folder with sent items Using Outlook 2
I Outlook 2010 Print Created Date on Drafts Using Outlook 3
P Print multiple pocket calendars on one page Using Outlook 5
