OL2003 Macro disables itself - looking for way to automate 'enable'
JackPollack
Using Outlook 2003, Windows 7 64Bit, IMAP.
Since OL2003 doesn't let you specify a Sent Item Folder and stores IMAP sent items on the local machine (which is pretty stupid, if you are using IMAP) I have created a rule that copies sent messages to the server so they are accessible from my other computer.
This works fine, except periodically the rule becomes unchecked (it is the only rule I have so I don't know if it just that rule or every rule that would uncheck).
It is a big problem when I am working on my laptop and find that no sent items have uploaded for several days.
I was going to write a macro that enabled the rule but it doesn't appear that OL2003 has a interface to the rules. Since the rules are stored in the pst file I dont see any way of protecting them there. Even a macro that sends key strokes would be hard since I would know if the macro was enabled or disabled at any given time.
Help!
Any ideas? add-ins?
I dont want to switch to OL2007
Forum Admin
IMAP support in Outlook 2003 was pretty bad. It's better in 2010 - and you can now pick the sent and deleted items folders.
The rule becomes unchecked because it loses contact with the server and fails. You can't run rules using a macro - but you could use a macro to move messages in the sent folder to the imap sent folder. See if outlookcode.com has any code samples. While this won't enable the rule if its disabled, it will help if it's disabled. I'd try running it on application send - but you may need to run it manually, like at the end of the day, before you close outlook. (I wouldn't set it to run on application close though.)
JackPollack
Why the rule deactivates makes sense.
I just wrote a few lines of code to move messages from local sent items to IMAP follder and put it ins the message send event. It appears to work perfectly
C Cannot access macro menu in OL2003 Outlook VBA and Custom Forms 2
T From OL2010 Pro to OL2003 Pro Using Outlook 4
J OL2003 (HTTP proxy) update time Exchange Server Administration 7
P migration issue from OL2003 to OL2010 with custom contact form Using Outlook 7
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
S OL2003 labels in OL2010 Using Outlook 7
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
W OL2003 & VB6:- "Could not send the message" Outlook VBA and Custom Forms 7
C Converting users with BCM in OL2003 to RPC over HTTP BCM (Business Contact Manager) 1
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
