Configuring Navigation shortcuts
chettacka
My Outlook 2003 correctly shifts among Ctrl-1/Email; Ctrl-3/Contacts; Ctrl-4/Tasks; etc... However, Ctrl-2 shifts to the Calendar navigation bar, BUT continues to display the last-viewed pane. E.g.: If I use Ctrl-2 to switch to Calendar from Email, all that switches is the Navigation bar (on the left). The view pane remains the same...
It's a quirk of mine: I want it to work. At one time it did. I have spent hours over months going through menus and searching online. I haven't found my answer; but, I haven't found the question either!
Chet
chettacka@earthlink.net
Forum Admin
I recall seeing this complaint before but i don't recall the fix. Verify you have all updates installed (can do this from Microsoft update on Windows Start menu or Outlook's help menu).
Is the calendar folder highlighted in blue or is it just outlined with a dotted border? I recall outlook today caused outlook to lose focus on the calendar. If you use Outlook today at start, go into Tools, options, other, advanced and select a different Start folder. Otherwise, avoid it and see if the problem goes away. (In a quicky test here, it does cause the navpane list to lose focus but the calendar still loads in the center pane.)
Try resetting the view on the folder - does the calendar eventually display or can you bring it up using other methods? If so, go to view, arrange by, current view, customize and click Reset. This will only reset this view, not all custom views you might have.
chettacka
I updated within hours of re-attempting a fix. Default opening view is email. Using "Ctrl-" or the folder buttons under the nav menu to change to the Calendar view, it is highlighted. You see however, the prior view (whether it's email or contacts...) [I tried creating an attachment, but the size limits are too restrictive.]
Reseting the view only shrinks my Sat/Sun..
Does MS still support 2007? Most problems are availabe in both versions, it seems. They wouldn't let me post a question about an Office 2003 product....:rolleyes: [< I don't do this stuff..... normally....]
THANKS FOR YOUR INPUT!!
Chet..
Forum Admin
if you don't have a skydrive account (available with a live id, aka passport, aka hotmail address) you can post screenshots at xsolive.com - there is an outlook screenshot gallery there. Although, I'm not sure its needed for this.
Outlook 2007 is still in support. Where did you try to post an Outlook 2003 question?
C Configuring Inbox columns Using Outlook 2
Diane Poremsky Configuring SmartPhones to use EAS to Outlook.com New Slipstick.com Articles 0
B Configuring MS emails Using Outlook 8
Diane Poremsky Configuring an Outlook.com account in Outlook New Slipstick.com Articles 0
Diane Poremsky Configuring a Manual Send and Receive in Outlook New Slipstick.com Articles 0
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
V Configuring a new IMAP email account in Outlook 2007 Using Outlook 4
V iCloud Configuring @me.com in Outlook (updated) Using Outlook 1
B Microsoft office outlook 2007 showing configuring outlook accounts for hours Using Outlook 6
M Configuring Outlook 2010 Using Outlook 5
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
Diane Poremsky Outlook's Folder Navigation Pane Disappears New Slipstick.com Articles 2
D Mail accounts don't show up in navigation pane Using Outlook 1
L Navigation Pane selection with shortcuts Using Outlook 2
T Unexpected change of the order of the folders in my navigation pane Using Outlook 6
T Occasionally, no vertical scroll bar in navigation pane in Outlook 2013 Using Outlook 9
A BCM is not in the navigation line BCM (Business Contact Manager) 2
K bcm not showing in outlook 2013 navigation pane BCM (Business Contact Manager) 3
O Outlook 2013 not holding bottom navigation settings Using Outlook 10
M Calendar navigation displays previous field records.check calendar is shared.. Using Outlook 3
M Add small calendar to navigation Using Outlook 1
D Views with the ToDo Bar and Navigation Pane Using Outlook 1
J How To Change Font Size For Folder Names on Navigation Pane in Outlook 2013 Using Outlook 1
L Navigation Pane Using Outlook 2
N Backing Up Navigation Pane Customizations - WinXP Using Outlook 11
G navigation pane wishlist Outlook Wishlist 0
J Add Option to remove "Links" area form Navigation Pane Outlook Wishlist 3
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
N How to disable shortcuts for Pilcrow in Outlook Using Outlook 0
Diane Poremsky Shortcuts and the Missing Outlook:// Protocol New Slipstick.com Articles 0
L any ways to create shortcuts to a public mail folder Using Outlook 4
Commodore Favorites vs. Shortcuts Using Outlook 1
T Displaying Shortcuts in Outlook 2010 Using Outlook 7
L Macro Shortcuts Using Outlook 1
L Outlook 2007 Keyboard Shortcuts Using Outlook 8
R Custom Keyboard Shortcuts for 2010 Using Outlook 3
D Outlook and the Dreaded Losing Shortcuts Issue Using Outlook 4
D Shortcuts in Outlook Business Manager not wokring BCM (Business Contact Manager) 3
J Outlook 2000 "My Shortcuts" question Outlook VBA and Custom Forms 2
P Ability to define shortcuts to folders Outlook Wishlist 2
