VBScript does not run in Outlook 2003
N
N Motihar
I am having an issue between outlook 2000 and 2003 forms. Custom form
that works in outlook 2000 now does not fire event or runs vbscript in
outlook 2003 client. Original form has "Send form definition with Item"
unchecked. If I check this and publish form in our test environment, vb
script does not execute on Outlook 2000 and Outlook 2003.
I need to make the vbscript on form work on both (outlook 2000 and
2003). Any suggestions would be appreciated.
H
Hollis Paul
Outlook versions have never been backward compatible. You have to use
the outlook object browser in 2003 to find the new names of the
variables that you want to use. Then include branching test to make
sure that a form instance running on 2000 only executes the 2000 code,
and a form instance running on 2003 only executes the 2003 code. Lots
of fun, no?
Hollis Paul
Mukilteo, WA USA
Sue Mosher [MVP]
I don't know why you'd say that. Even in Outlook 2007, which has a Folder
object, MAPIFolder still works for backward compatibility with existing
code.
I would be looking at possible causes of one-off items and wondering where
this form is published and what folder(s) it's used in.
Sue Mosher,
TmFyZXNoIE1vdGloYXI
Hi Sue,
Thanks for the article. I have published the form and here is more
information I found. If I publish the form on Personal Forms Library folder,
the code behind the form executes in Outlook 2003, but publishing the form on
Organizational Forms Library causes the issue where the VBScript does not
run. Could this be related to permission issue?
Naresh
Sue Mosher [MVP]
You didn't check the "send form definition with item" box on the Properties
page of the form, did you? Never do that on a form with script.
Sue Mosher,
D Security patch seems to kill vbscript on Enterprise Level Outlook VBA and Custom Forms 4
R VBScript Commands Outlook VBA and Custom Forms 2
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
R VBScript Sendmail not selecting correct 'from' address Outlook VBA and Custom Forms 3
B Recommended Outlook & VBScript Books? Outlook VBA and Custom Forms 3
K VBScript Outlook, add attachment Outlook VBA and Custom Forms 1
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
E VBScript to replace module? Using Outlook 3
F VBScript to add pre defined text Using Outlook 5
D Custom form and VBScript Using Outlook 5
F VBScript copy contacts and remove duplicates Using Outlook 1
H Accessing a control on a frame in Outlook with VBScript Outlook VBA and Custom Forms 1
Y Creating a Task with VBScript Outlook VBA and Custom Forms 14
N Free/busy publish at http location does not work Using Outlook 1
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
