Stationary and view layout keep changing after reboot?
pjwinstalls
I have changed my stationary to Calibri 12 in all three fields contained within stationary. My view type is set to preview and my reading pane is to the right. But everytime my computer reboots, which has been daily lately.... all of those changes i made revert to defaults. Any thoughts on how to fix this? It only became a problem recently when i reinstalled outlook and office.
Philip
larry
Are you closing Outlook before rebooting? Close it, then verify it is closed by looking in Task Manger, Processes tab. If Outlook is left running, some changes are not permanently committed to the registry. Sync utilities and other addins can prevent outlook from closing. OUTLOOK.EXE continues running after you exit Outlook
Also, is this a work or home computer? A group policy could be controlling this on a work computer.
W Outlook Stationary Font Formating Problem Using Outlook 7
S automate outlook stationary Outlook VBA and Custom Forms 1
N create stationary in outlook Outlook VBA and Custom Forms 1
Commodore MHT files (from "View in browser") Using Outlook 7
J Split reading view with history Using Outlook 2
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
copperberry How to view all tasks across task folders Using Outlook 3
A Day view - print appointment details Using Outlook 1
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
B outlook view control Outlook VBA and Custom Forms 0
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
