How to Create Macro in Visual Basic to add Contacts from Personal Folder
mickash
:confused:Help! My contact list on a prior system was deleted. I have imported all of my emails into my new Microsoft Outlook 2003 but going through all the emails individually to add contacts is horrible when you have thousands of emails. Does anyone have the micro basic code to set up a macro to add contacts from the personal favorite folder?
i.e. click on a message, right address, click on add to contact list, then click on save and close (when outlook creates contact)?
I would really appreciate all the help I can get. Visual Basic looks like greek!
Forum Admin
there are addins you could use - at least i think they might work as you need to use something you can run on mail in your folders.
Here is a code sample that adds them when replying - http://www.outlookcode.com/d/code/autoaddrecip.htm - you'd need to change it to do it on all messages. (I'll check around and see if anyone has sample code that better meets your needs.)
We have a long list of tools here: http://www.slipstick.com/contacts/addauto.asp - but I'm not sure if any can go through folders and create contacts. (the custom action sample would be prefer using run rules now but it need compiled.)
Forum Admin
Here you go - compliments of at http://www.slovaktech.com
The macro will work in any selected folder on all selected items in that folder.
Any selected mail items will be harvested. Because I wanted to only use the OOM and you didn’t say if this was 2007 or later only, I didn’t use the MAPI properties for SentOnBehalfOf* other than for name. So the email addresses may not be accurate (for example mails sent to mailing lists will show the list address, not the actual sender's address.)
If this were 2007 or later code only I’d use PropertyAccessor to pick up the PR_SENT_REPRESENTING_ADDRTYPE and PR_SENT_REPRESENTING_EMAIL_ADDRESS properties instead of using SenderEmailAddress and SenderEmailAddressType.
A text file of this code is here: http://www.slipstick.com/contacts/_oft/save-addresses-to-contacts.txt
' The AddAddressesToContacts procedure can go in any Module
' Select the mail folder and any items to add to contacts, then run the macro
Public Sub AddAddressesToContacts()
Dim folContacts As Outlook.MAPIFolder
Dim colItems As Outlook.Items
Dim oContact As Outlook.ContactItem
Dim oMail As Outlook.MailItem
Dim obj As Object
Dim oNS As Outlook.NameSpace
Dim response As VbMsgBoxResult
Dim bContinue As Boolean
Dim sSenderName As String
Set oNS = Application.GetNamespace("MAPI")
Set folContacts = oNS.GetDefaultFolder(olFolderContacts)
Set colItems = folContacts.Items
For Each obj In Application.ActiveExplorer.Selection
If obj.Class = olMail Then
Set oContact = Nothing
bContinue = True
sSenderName = ""
Set oMail = obj
sSenderName = oMail.SentOnBehalfOfName
If sSenderName = "" Then
sSenderName = oMail.SenderName
Set oContact = colItems.Find("[FullName] = '" & sSenderName & "'")
If Not (oContact Is Nothing) Then
response = MsgBox("This appears to be an existing contact: " & sSenderName & ". Do you still want to add it as a new conact?", vbQuestion + vbYesNo, "Contact Adder")
If response = vbNo Then
bContinue = False
If bContinue Then
Set oContact = colItems.Add(olContactItem)
With oContact
> Body = oMail.Subject
> Email1Address = oMail.SenderEmailAddress
> Email1DisplayName = sSenderName
> Email1AddressType = oMail.SenderEmailType
> FullName = oMail.SenderName
> Save
Set folContacts = Nothing
Set colItems = Nothing
Set oMail = Nothing
Set obj = Nothing
Set oNS = Nothing
A Create Macro for hyperlink(email) in message body Outlook VBA and Custom Forms 9
L Macro Create Contact and Save Using Outlook 2
L Macro Create Contact and Save Using Outlook 8
S Macro to create notification emails Using Outlook 1
N Macro to create task Using Outlook 1
S Macro to create a new folder with subject line as the folder name Using Outlook 2
P Please Help me Create a Macro ! Using Outlook 2
S Macro to create a new contact, 2 appointments, and a task Using Outlook 1
C Outlook VBA - Create Macro Move Contact field Item to Another Using Outlook 1
R How do I create a macro to put text in certain emails? Outlook VBA and Custom Forms 1
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
N How Can I create an Outlook Macro to import calendar? Outlook VBA and Custom Forms 1
P How do I create a macro to add contacts from email messages? Outlook VBA and Custom Forms 1
J Macro to create folder in PST file Outlook VBA and Custom Forms 4
G Macro: Create New Message and Auto populate To Field Outlook VBA and Custom Forms 5
S How to create a macro to insert a signature in Outlook 2007 Outlook VBA and Custom Forms 1
C Can't create Outlook data file Outlook Wishlist 0
Diane Poremsky Create a Task when a Message is Flagged New Slipstick.com Articles 0
Diane Poremsky Create a custom field for Outlook messages New Slipstick.com Articles 0
