drag drop/opening drop down/single click acts like double/highlighting
tbenton
Outlook 2007
:mad::mad:
I have had Office and Outlook 2007 for over a year. Once before it acted strangely and I did something that fixed it and I usually document all fixes but I didn't and its acting up again. Seems that it was something simple/stupid.
Here is what is going on:
> hard to drag/drop mail item to a folder; opens it instead of moving but sometimes it works
> highlight message to delete or move and it opens it (single click acting like double click)
> highlighting text is almost impossible. Won't let me start and stop where I want to and even when I can the highlight disappears sometimes when I release mouse
> using scroll bar on right side is like pulling teeth
> when I click on mail folder to see subfolders it closes before I can even look/select or it opens and when I release mouse it closes. Same thing when I try to use any drop down menu but after several tries the drop downs/folder stay open
Some of these things happen in WORD 2007 also AND on my browser (I.E. and Firefox) so I did what I thought was appropriate to diagnose...
I run Win XP and Office 2007 and am the only user of this PC. Ran Windows diagnostics as there is no detect and repair in Outlook 2007. Ran Windows/Office Update. The last software that updated was Adobe Flash so I removed all Flash programs but still acting up. And Yes I rebooted after each 'action' to fix.
This is driving me to distraction. Hope someone can help.
Terri
Forum Admin
What antivirus software do you use? Are you using a 3rd party popup blocker? Some (but not all) of your symptoms can be caused by an aggressive popup blocker. The standard blockers in browsers will not cause problems.
tbenton
Outlook 2007
I use Norton Security Suite and nothing has changed. I don't use any third party pop up blocker. Bottom line is that the only thing that changed from everything being fine to things going haywire was an update to Adobe Flash....sooo.... I removed all programs associated with Flash but it made no difference.
Its really strange behavior
Terri
Close Outlook and restart in Safe mode - see if it works as expected. If so, we know its either norton or another addin. (Hold Ctrl as you click on the Outlook icon to start in Safe mode.)
does it always do this with all items or folders or does it only happen occassionally or with specific items or folders?
tbenton
Outlook 2007
thanks for the reply. I started in safe mode and seem to have same issues. Its really odd that in either mode sometimes when I select a mail item it opens as though I had double clicked it. Its not always the same items and seems random as does the ability to move a mail message to a folder with drag and drop. Also highlighting text and having the exact text stay highlighted long enough for me to take some action seems rather random and does it in both modes.
I have had Norton Security Suite for a long time and cannot imagine what would cause it to affect Outlook like this but I will try whatever suggestions you have.
Terri
if its not fixed in safe mode, its probably not norton.
Make sure you have updated video drivers as well as mouse drivers - video drivers can cause weird behavior like this.
tbenton
Outlook 2007
Everything is up to date but thanks for the hints and guess what? Outlook is back to behaving normally and I did NOTHING to help it! I am the only one who used this computer so I am totally stunned. It started acting up all of a sudden and two weeks later its B a a a c k.
Terri
I'm guessing either or both a) a reboot fixed it or b) an automatic update...
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
K Cannot consistently drag and drop .msg files into Outlook 2010 Using Outlook 0
F Tumblr - Drag & Drop files (pictures) into Outlook? Using Outlook 12
C Cannot drag and drop or create folder in PST file folders Using Outlook 1
Forum Admin Wishlist Drag and drop email to a calendar date Outlook Wishlist 1
L Copying Emails using drag and drop Using Outlook 2
V Drag and drop into Outlook folders Using Outlook 2
R Outlook 2007 - drag drop email to Explorer Using Outlook 1
J Problem using drag and drop to attach an html email in Outlook 2010 Using Outlook 18
S Drag and Drop in Outlook 2010 Using Outlook 1
J Drag and drop contacts into an calendar Using Outlook 1
J OWA copy/paste and drag/drop Question Exchange Server Administration 2
R Mail disappeared when cancelling a drag and drop 'move folder' Using Outlook 1
B Can not drag and drop attachments Using Outlook 3
H Drag and Drop Outlook mails into a Windows Form Control with eml extension Outlook VBA and Custom Forms 1
A turn Outlook into a Drag-and-drop application Outlook Wishlist 2
M Drag and drop Outlook VBA and Custom Forms 1
N Drag and drop attachment in outlook addin Outlook VBA and Custom Forms 4
S Drag-and-drop to Custom Task Pane Outlook VBA and Custom Forms 2
A Implementing Drag and drop events in outlook Outlook VBA and Custom Forms 7
P Drag and Drop mails from Outlook to Clarion6 Application Outlook VBA and Custom Forms 5
S Renaming while drag and dropping to file Using Outlook 1
B Right click-drag no longer creates hyperlinks Using Outlook 2
T Can not drag e-mails from search to folders Using Outlook 1
B drag an email to the calendar Using Outlook 2
R Folders disappear when I drag an email from the Inbox to them Using Outlook 1
D When I drag a message from my Inbox to another folder, the target folder disappears and only reappea Using Outlook 2
S cannot drag emails to personal folders BCM (Business Contact Manager) 1
B See "Change View" Drop Down as a List? Using Outlook 1
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
A Automatically send email based on drop-down field? Outlook VBA and Custom Forms 2
Diane Poremsky No drop down calendars in Outlook 2010 Print Options New Slipstick.com Articles 0
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
P Field in Forms displayed depending on the Item chosen from drop-down-list BCM (Business Contact Manager) 1
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
M How do I link a drop down box to a percent complete box Using Outlook 4
R Display multiple accounts as drop down in the from field in New Mail Using Outlook 1
L Drop down menu box in Office 2003 are too small. I cannot see all the information to fill out serve Using Outlook 2
C Outlook 2007 Menu Bar "View" One Folder has Drop Down Box with "Arrange By", One Does Not Using Outlook 14
P Cannot create connected drop down list in Outlook 2007 forms Using Outlook 1
A Change options in Phone drop down lists Using Outlook 1
R Cannot open sound drop down box Using Outlook 1
L In the File drop menu 'Import/Export' does nothing when I click on it Using Outlook 1
D How to setup an SMTP Drop and Queue Folder in same Domain for relay??? Exchange Server Administration 4
S Outlook addin formregion as a drop down Outlook VBA and Custom Forms 6
S RE: Template with drop down Outlook VBA and Custom Forms 3
C Drop Down Box in Email Template Outlook VBA and Custom Forms 2
