outlook 2003 always not remove temp copy of opened attachments in temporary fo
c.itech
Outlook 2007
When outlook 2003 open an attachment, a temp copy of opened attachments will stored in temporary folder, when attachment closed, Outlook will remove the temp copy automatically, but my Outlook not remove automatically, any ideas? Thx!
Re: outlook 2003 always not remove temp copy of opened attachments in temporar
the attachment is only removed if you close the attachment then close the message (or change messages in preview). If you open an attachment from the preview pane then view the calendar or another message before closing the attachment, its left behind.
See http://www.slipstick.com/outlook/securetemp-files-folder/ for more info.
c.itech
Outlook 2007
know need to follow such sequence to have temp copy removed, but it's still not working, really strange, all temp copy left here no matter what sequence I take to close messages/attachments, at last, choosen to put below in windows startup : )
del /q /f "c:\Documents and Settings\username\Local Settings\Temporary Internet Files\OLK68\*.*"
Thx!
I wonder if antivirus or something is interfering as they should be deleted if the link between the message and attachment is not broken - basically you can't do anything in outlook until you close the attachment.
BTW, You know that outlook may replace the path at any time? A wildcard for olk* would be better.
c.itech
Outlook 2007
thx! will leave olk68 for now until user report problem again (path changed), then find out how to deltree with wildcard, not did that before : )
B Outlook 2003: Meeting Organizer will be set as always free or busy status Using Outlook 1
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
R Outlook 2003 not working Using Outlook 13
C Outlook 2003 displays wrong account in IMAP Using Outlook 5
