Default IMAP account not working after SP1 for Outlook 2010 installed
nicke
I uses Outlook 2010 32-bit on a Windows 7 64-bit. I have earlier installed this http://support.microsoft.com/kb/2547227 hotfix to have my IMAP account as a default sending account and it have worked perfect. I have an IMAP account as my default account and a Hotmail account to sync my calendar and contacts with my Smart Phone and my secondary computer.
But after installed SP1 for Office 2010 when I click on a file and select 'send to' -> 'mail reception', in the Outlook windows I see my IMAP address as the from address. But the email is sent from my Hotmail address. It does not mater how I switches between the sending addresses (Hotmail/IMAP), the email is always sent from my Hotmail address.
When I create an email by clicking 'new mail' in Outlook, the sending address is correct, so it is only when a uses the 'send to' -> 'mail reception' on a file that I have problem... :confused:
Regards,
Nicke
pepelepieux
You can always try to uninstall the hotfix and see if that resolves the problem.
Forum Admin
Those are the only two accounts in the profile? I'll try to repro it...
The solution may be to make a new profile but that can be painful with large imap and hotmail mailboxes.
Forum Admin
oh, and more thing - have you tried changing the default accounts - switch it to hotmail then back to imap.
nicke
I have now tested a second computer, the same problem...
G How to make your IMAP email your default data account in Outlook 2007 Using Outlook 17
D Default calendar and IMAP Using Outlook 1
J Exchange 2010 + Disable ActiveSync/Outlook Anywhere/POP/IMAP/ By Default Exchange Server Administration 5
M aoutlook 2010 sent from is not using default imap Using Outlook 1
M Default send address when replying from IMAP linked accounts Using Outlook 1
O How come default profile changed? Using Outlook 2
T Outlook changes default account Using Outlook 1
V VBA when replying + Default Account Using Outlook 2
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
P Outlook 2016 Not Default Client Using Outlook 5
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
N How to delete default folder "Contacts" (olFolderContacts) in a .pst file Using Outlook 8
D Default Send Account that Works? Using Outlook 0
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
J Setting default address book Using Outlook 0
C Change default colors for conditional formatting Using Outlook 2
S Default Font in body of Task Using Outlook 0
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
Diane Poremsky Shared Mailboxes and the Default 'Send From' Account New Slipstick.com Articles 0
Diane Poremsky Working with VBA and non-default Outlook Folders New Slipstick.com Articles 0
Diane Poremsky To Change the Default E-mail Program in Windows New Slipstick.com Articles 0
C Delete Subject-Add Organizer to all Reservations in Default Calendar. Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts New Slipstick.com Articles 0
B Outlook 2016: Can't delete default calendar but I don't use it Using Outlook 7
B Calendar shows too much info by default Using Outlook 0
M Default Calendar Using Outlook 0
L Change default from english to danish ...... Using Outlook 5
R Making Outlook default client in share charm Using Outlook 4
