set deafult view in public folder for all users from outlook 2010 64bit
bsingh
Hi all,
Looking for help to set default view for the public folder for all users from outlook 2010 64bit. In outlook 2003, there was administration tab from where you can set the default view of the folder for all the users. There was option called " Initial view on Folder" and you can choose your view like by category or by subject or customised category you created from view | Current View | Define View.
But in outlook 2010, it allows to create new view from the view tab on the ribbon | go to change view and manage views. Here you can create your view. When you select new it prompts "Can be used on" and I selected This folder, visible to everyone. Then I set the view and publish the view. When you publish, it prompts "Are you sure you want to publish the view "name" ? You changes will be visible to all users of this folder"
After I gave time to synchorise, I can see other users have view under change view tab on outlook 2010 but it does not force other users the view I selected. I would like to know as administrator how can I force or set the view of particular public folder to all default users who has only reveiwer access.
Thanks in advance.
F how do i set a reminder in onenote 2010 Using Outlook 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
O Set columns for all (sub)folders Using Outlook 8
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
F Set (flagged) reminder for next business day Using Outlook 4
L how to set downloaded cached emails Using Outlook 5
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge New Slipstick.com Articles 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
M Exchange 2013 On premise set MessageRateLimit for User has no effect. Exchange Server Administration 0
A Block user to send emails to specific set of email ids Using Outlook 1
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
Diane Poremsky Exchange account set-up missing in Outlook 2016 New Slipstick.com Articles 0
M To set the storage folder for an outgoing Outlook message Outlook VBA and Custom Forms 8
E Meeting reminders are set for the recipient Exchange Server Administration 9
M Help! Can't set up IMAP for gmail Using Outlook 2
P Last Change attribute set after viewing a public folder contact Exchange Server Administration 0
S Multiple Gmail account set up in Outlook 365 Using Outlook 1
Diane Poremsky Add attachments and set email fields during a mail merge to email New Slipstick.com Articles 0
D Script to parse email and set a task Outlook VBA and Custom Forms 1
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
A set onedrive calendar as default in Outlook Using Outlook.com accounts in Outlook 4
reefclaw Outlook 2013 Cannot set outlook.com account as default data file Using Outlook.com accounts in Outlook 3
Q set as default Using Outlook 5
R Notification/alert when an email has been sat in inbox for a set period of time Using Outlook 1
