Outlook 2002 - How to upgrade to 2003 and convert PST from ANSI to Unicode?
Porty
Older version
This seems to be an issue that concerns many users.It also seems to be hard to get accurate (and simple) advice on the best way to do it.Hopefully, I've come to the right place now :)A friend has a working instalation of Outlook 2002.Her PST has grown to be 1.7G.I'm aware that if the PST reaches 2G, Outlook may crash.I want to upgrade Outlook to 2003.But as far as I'm aware, the upgrade will not convert the PST from ANSI to Unicode.Can some kind person confirm this please?And perhaps suggest the best way to do the job?Thanks :)
Porty
Older version
Re: Outlook 2002 - How to upgrade to 2003 and convert PST from ANSI to Unicode
Diane, thanks for your response. One more query - if it's in your area.
I'm new to this site. My browser of choice is Firefox. But with Firefox, the posting area doesn't respond properly. Like, I can't see the curso. Hitting Enter doesn't get a line break, can't backspace etc etc.
Seems like the board is optimised for another browser.
Any idea which one? I'm typing this now with Opera but it's not 100% either.
Cheers :)
It should work fine in all browsers - and seems to be fine in the latest FF. I have noticed that text boxes in FF can be goofy at times, especially when the browser has been open a while.
Which editor option do you use? On the left is the A/A button - it switches between source and wysiwyg mode - and there is the Go Advanced button which also has the source and wysiwyg mode.
Porty
Older version
Actually, I've used Firefox to post on several hundred boards over the years and never ran across this particular problem. But I've just tried your suggestion and modified the input method from Advanced to Medium and that's fixed it. Thanks.
BTW, re the pre-2003 Outlook data files, are they actually PST? Or were they known as OST? Also, is there a way to tell from the file properties whether such a file is ANSI or Unicode? I'm interested to know if I carry out a conversion, there's any way of telling if it worked.
When you view the pst properties - file, data file management or right click on the pst in the folder list and choose properties, then Advanced button - if the properties page saud Outlook 97-2002 format, its ANSI. If it just says outlook data file (and you are using outlook 2003 and up) its Unicode.
The data files for pop3 and imap are pst files. Hotmail and exchange use ost files - all you need to do is delete an old ost and they'll be created in the new format. Same for imap - outlook chooses the format for you.
Porty
Older version
Thanks Diane - a very informative answer :) I'm just about ready to tackle my friend's problem.
Here's another oddity about the board's format. I was emailed a notification that you'd replied to my question. I clicked the link (in Outlook Express) and was taken to the board.
Note that, at this point, I'm not logged in. But I can see your Avatar (and very nice, too :)
So, I go to reply, which requires me to logon. I logon and oops - Diane's Avatars aren't visible.
Any ideas about this? It's not crucial but I'm always curious about why computer things work (or don't).
Cheers :)
Forum Admin
There is an option in user profiles where you can choose to not display avatars (or signatures or images). You have them disabled.
L Outlook 2002-2013 upgrade Using Outlook 3
S Transferring POP emails from Outlook 2002 to Outlook.com email in Outlook 2013 Using Outlook.com accounts in Outlook 8
D Syncing Outlook 2002 with iPad 128 KB Using Outlook 1
A moving outlook 2002 from xp to win 7 or 8 Using Outlook 2
D Outlook contacts no in address book - 2002 pst file convert to 2007 pst file? Using Outlook 0
K Outlook 2002 Can Not Send Or Receive E-mails Using Outlook 3
P How can I view a german email in outlook 2002? Outlook VBA and Custom Forms 1
D I need to know everything about Outlook 2002/XP Forms ! Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 6
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 0
D Connecting Gmail to Outlook 365 - My Setup not working Using Outlook 1
K Outlook tasks formatting Using Outlook 4
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
H I have no profile listed for Outlook! Using Outlook 9
D Outlook 2016 how to use gmail account as source account for outlook 365 Using Outlook 9
Horsepower Contacts added from iPhone don't show up in Outlook Using Outlook 1
A Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
L Outlook saved template function too limited Using Outlook 2
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
witzker Open Contact missing in Outlook 2019 Using Outlook 2
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 5
K Imap PC Outlook + Android phone Using Outlook 1
