Please help! Outlook, Exchange Server, and Customization
bkirish
Here's my problem. My office is running Outlook 2007 and using a Microsoft Exchange Server. This is working swimmingly, no issues there. However, by boss would like to use some customized fields to help us with our marketing. Basically, we want to be able to use our own fields to determine who gets particular forms of marketing and who doesn't.
Now, here are the fragmented issues I have run into in my quest to solve this seemingly simple problem. If I am wrong about any of these, please let me know:
1. User-defined fields in Outlook's regular Contact interface cannot be exported and are not searchable.
2. There are four fields called "User Defined Field 1, 2..." that ARE exportable, but you cannot change the name of those fields.
3. You can use Business Contact Manager to create user-defined fields that are exportable and you can change the name of these fields AND where they show up. However, you cannot sync contacts in BCM through an Exchange Server, it must be done over a LAN connection. This would cause problems for us, as our office's infrastructure is heavily dependant on the lovely syncing capabilities of our Exchange Server.
4. There are limited resource for third-party add-ons. The only one I found that supports syncing over Exchange is Avidian's Prophet Business Contact Manager for Outlook, but they want to charge our small business of 14 people $11K to do it. Not going to happen.
So, here I am. I am looking for any way around this problem. We either need to find a way around it in Outlook's Contacts (finding a way to export customized, user-defined fields to Excel mailing lists), find a way to happily marry BCM and our Exchange Server, or find a third-party system that allows us to customize our fields, sync with our Outlook Contacts and our Exchange Server. Is that too much to ask? Any insight would be much appreciated. Cheers!
C Please Help outlook 2013 Using Outlook 1
F Help with Outlook 2007 Macro Please! Using Outlook 4
A outlook error Receiving reported error (0x80040900) please help Using Outlook 4
D Help please my Outlook is frozen Using Outlook 3
H Outlook 2010: Cannot start!, please help me! Using Outlook 3
D Outlook 2007 not working>> Please help tried everything Using Outlook 3
U Need a help please Outlook 2007 crashing Using Outlook 2
B Please help! Outlook, Exchange Server, and Customization BCM (Business Contact Manager) 2
C outlook hotmail connector update killed my outlook - please help!! Using Outlook.com accounts in Outlook 3
R i want notifier in outlook express , please help how can i get ? Outlook VBA and Custom Forms 1
C Outlook 2007 Wacky Issue - Please Help Outlook Wishlist 1
V Outlook macro help please Outlook VBA and Custom Forms 23
A Help with VBA please! Outlook VBA and Custom Forms 15
J Please help to clarify an IMAP issue Using Outlook 7
M Address book doesn't update contacts? Please any help would be great! Exchange Server Administration 4
N Please help....winmail.dat issue...slowly going insane..... Using Outlook 1
A help please -Boolean - can I use .AND NOT etc in a rule Exchange Server Administration 0
C Can't import distribution list - help, please Using Outlook 1
V [duplicates duplicates duplicates] please help Using Outlook 26
I can't view email body please help! Using Outlook 6
S Please help! -- Linked Account field at Business Contacts tab is always empty BCM (Business Contact Manager) 1
M Updates to exchange server broke code - please help Using Outlook 2
K shared inbox help please Using Outlook 0
P Please Help me Create a Macro ! Using Outlook 2
J Help please Using Outlook 30
D A little bit of help with headers please? Exchange Server Administration 1
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 5
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 1
D Please help. My live.edu mail will not sync. Using Outlook.com accounts in Outlook 1
M Help with shared BCM file please BCM (Business Contact Manager) 5
R SQL Server Setup failed - Please help?! BCM (Business Contact Manager) 2
L Please help an idiot with BCM & Networking... BCM (Business Contact Manager) 5
V Import multiple vCard files!!!!!!! PLEASE HELP Using Outlook 2
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
Diane Poremsky Testing please ignore Using Outlook 1
