Printing problems with MS Outlook 2000
pn1
Older version
Hello there. This is my first post so I trust it is in the correct section.
Recently I had a new hard disk installed on my computer. I hadn't used MS Outlook for some time because it didn't work on the old disk. In the interim, I had been using Thunderbird.
With the new disk and Windows XP home edition installed, I reinstalled Outlook 2000 and it seemed to be working OK for a few days.
However, I noticed I was getting an increasing number of "not responding" and "error report" messages.
Today it won't print. I have tested the printer (using MS Word 2000) and it works fine. I use FinePrint software and it works fine.
I wonder if Outlook 2000 is simply too old and/or too much trouble? Should I return to Thunderbird (that seemed to work OK for me)?
Thanks in advance for any assistance.
Paul in Australia
Outlook 2000 is old but it should run fine on windows xp. However, because its old, its less secure- and that would be the main reason not to use it.
Do you need the features Outlook offers? Does Thunderbird meet your needs? The answers to those questons should quide your choice of email client.
Do you have all updates installed for Office 2000? It should say Office 2000 SP3 in Help, About.
E Outlook 2010 network printing problems Using Outlook 4
A Problems printing multiple emails Using Outlook 1
A How to use calender printing? Using Outlook 1
M Printing Appointments Using Outlook 1
M Calendar daily Appointments and printing Using Outlook 0
T Printing from Outlook is now defaulting to "Shrink to Fit"! Using Outlook 5
snissen Printing foreign language messages Using Outlook 1
L printing contacts Using Outlook 1
A How to get rid of Contacts field when printing emails? Using Outlook 0
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
D Printing Contacts Using Outlook 2
C Printing tasks with multiple categories Using Outlook 5
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
S macro for opening attachments and printing Using Outlook 1
J Printing Mulitple Calendars Outlook VBA and Custom Forms 1
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
G booklet printing in outlook 2007 Using Outlook 1
W Meeting printing background fields Using Outlook 0
K calendar printing Using Outlook 1
M Outlook 2013 is printing headers only Using Outlook 4
S So Disappointed in Calendar Printing Assistant!! Using Outlook 2
D Printing Attachments Automatically in Outlook 2010 Using Outlook 1
F Printing all day events only Using Outlook 3
J outlook printing Using Outlook 2
J Printing Calendar in Outlook 2013 Using Outlook 0
C Printing Outlook Form Controls via Word Using Outlook 11
E Printing Using Outlook 1
C Custom .oft / Printing Issue(s) Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
P Printing Issues in Outlook 2007 Using Outlook 1
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
I Printing Using Outlook 0
E Monthly Style Calendar Printing Using Outlook 6
S How to remove tracking from printing - outlook 2010 Using Outlook 4
P Printing calendar (work week) with numerous (i.e. >7) all day events... Using Outlook 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Using Outlook 2
E Adding Start and End Time to Daily View in Calendar Printing assistant Using Outlook 1
M Outlook 2010 task line printing Using Outlook 1
S Printing Selected Date Range in Monthly Style Using Outlook 1
S Does Printing Assistant Work with Windows 8 and Office 10? Using Outlook 1
A outlook printing assistant Help editing template Using Outlook 3
S Printing Category Key on Calendar Using Outlook 1
P Printing Issue on Calendar Printing Assistant Using Outlook 0
W Calendar Printing with Outlook 2010 (64 bit) Using Outlook 1
R printing fields in addresses Using Outlook 1
