Custom Forms Don't Always Auto-Forward From Public Folder
JTrana
Hello all,
Our environment:
Server: Exchange 2007
Clients: Outlook 2007 and 2010 (some cached mode and some not)
Client Operating Systems: Windows XP Pro 32-bit, Windows 7 Pro 32-bit, Windows 7 Pro 64-bit
We have a simple custom form that was originally created in Outlook 2003 which captures details of upcoming travel for an employee. There is no "code" (no VBA or anything like that) but rather just some fields that capture the information. This form is published to the organization and works flawlessly when posting to the public folder. The posted forms can be opened and display perfectly.
The issue we are experiencing is that we have set up the Folder Assistant for the public folder to forward the submitted postings to 3 staff members with a format of "Leave message intact". This forwarding works fine for most of our users but we have some Outlook 2010 in cached mode users for whom the postings are not forwarded at all; the posting works and the form appears in the public folder, it is just not forwarded. In other instances we have some Outlook 2010 in cached mode users who make a post and the forwarded message does not contain the form information but rather uses the standard message form instead so the form informaiton is not visible to the recipient without having to go to the public folder and opening the post.
I have been searching on this extensively but haven't come across any answers yet so any help or suggestions are much appreciated. Thanks!
Jason
B Outlook Custom forms Using Outlook 0
Cameron Piper Automatically update custom forms across multiple computers Outlook VBA and Custom Forms 1
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
Diane Poremsky Designing Custom Outlook Forms New Slipstick.com Articles 0
Diane Poremsky Publishing Custom Forms New Slipstick.com Articles 0
Nick Truscott Lost custom forms after moving mailbox Outlook VBA and Custom Forms 3
H Lost Custom Forms when we replaced Exchange Server Outlook VBA and Custom Forms 3
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
LarryH Custom Fields & Forms Using Outlook 3
P Creating custom contact forms Using Outlook 2
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
M Workarounds for sharing custom Outlook 2007 forms? Using Outlook 3
P Unable to delete custom forms in outlook 2010 Using Outlook 1
G Office Profession Plus 2010 is not working for custom forms Using Outlook 3
O Outlook custom forms (2003) Using Outlook 5
A Outlook 2013 corrupting custom forms? Using Outlook 34
M Custom Forms for Emails Using Outlook 4
K Custom Forms - Blank Message Received! Using Outlook 1
L Custom Forms Using Outlook 3
S Can I link custom designed forms to a specific calendar? Using Outlook 5
D Moving Outlook Custom Forms Using Outlook 10
S Outlook 2010 custom forms Using Outlook 4
T Custom forms BCM 2010; use of form controls Using Outlook 1
S Outlook 2010 custom forms Using Outlook 1
T Custom Forms Problem Outlook VBA and Custom Forms 1
K Find vs. custom forms Outlook VBA and Custom Forms 2
T Custom Contact Forms and User Properties Outlook VBA and Custom Forms 2
B Macros have been disabled error Message with Custom forms Outlook VBA and Custom Forms 17
G Custom Forms: Attachment to be included in Reply Outlook VBA and Custom Forms 1
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
Q More than one Notes section in custom contact forms Outlook VBA and Custom Forms 1
O custom forms Outlook VBA and Custom Forms 2
