Trouble Running Outlook 2007 and 2010
vipes27
We have 3 PCs running Office 2007 at one of our locations and everyone else running 2010. We have a user that moved to the larger location (using 2010) from the smaller one (2007) and is having issues launching Outlook at the smaller location when she goes back there from time to time.
When she moved to the new location, she had just gotten married, so her username and email address changed. When she logged into 2010, there were no issues but when she goes to the old location and logs in on 2007, she gets the following errors.
  1. You have a previous version on Microsoft exchange messaging service create a new profile.
  2. The mail profile (user) was created with a newer version of outlook and might contain information that is not compatible with your current outlook version if you experience problems you can create a new profile in windows control panel open mail then click show profiles then click add.
  3. Cannot open your default email folders the information store could not be opened.
I created a new profile for her new username, which works until she restarts and tries to open Outlook again. What can I do to resolve this?
Forum Admin
if she is using two versions of outlook and a roaming profile, she needs to use 2 outlook profiles - one for each version of outlook.
Create a profile in outlook 2007. Name it "Use with 2007". Repeat using Outlook 2010. Set outlook to ask which profile to choose - and she chooses the profile based on which outlook she is at.
vipes27
I'll try that. Is there a reason, though, that she is the only one that has issues? We probably have 5 or 6 users that login on the PCs with 2010 and 2007 and she's the only one that effected.
Forum Admin
on #1 and 2, they should all get the 'this profile was created in a newer version'. Are they all using roaming profiles?
Oh, and on 3, one cause is using Outlook in compatibility mode. If separate profiles doesn't help that error, check the compatibility settings on outlook.exe.
vipes27
No, none of the 'floaters' are using roaming profiles. The effected user did have a roaming profile but I had already removed that to see if it was the issue.
G Trouble with Office 365/2016 Using Outlook 3
M Trouble downloading Outlook on an Android phone Using Outlook 4
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
U Trouble migrating Contacts (2002) to People (2013) Using Outlook 3
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
B Trouble Adding @Outlook.com Email Accounts Using Outlook 3
K Trouble converting the ANSI PST to a Unicode PST Using Outlook 4
U Trouble for sharing Calendar Using Outlook 3
S Trouble setting up Outlook Connector to sync with windows live Using Outlook.com accounts in Outlook 3
N Trouble importing calender information from iPhone into OutLook 2010 Using Outlook 1
T Trouble with creating database BCM (Business Contact Manager) 1
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
K Trouble using SaveAs Outlook VBA and Custom Forms 3
M trouble connection to remote database BCM (Business Contact Manager) 1
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook New Slipstick.com Articles 0
Diane Poremsky Running Outlook Macros on a Schedule New Slipstick.com Articles 0
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
N Running multiple macros upon sending Outlook VBA and Custom Forms 6
G Error when running scanpst.exe Using Outlook 1
V Running scripts with Outlook 2013 Using Outlook 17
D Stopping "do you want to continue running scripts on this page" warnings Using Outlook 4
M Running macros in tasks sent out as meeting requests in invitees machine Using Outlook 4
N Rules stop running automatically Using Outlook 10
M Why rules stop running automatically? Using Outlook 1
S CSCANPST To Automate Running SCANPST.EXE Using Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
