BCM 2007 to Outlook 2010 with no BCM - need contacts imported
trmiller21
I've upgraded my Outlook from 2007 with BCM to 2010 without BCM and I am unable to see any of my BCM files. Is there a way to import my BCM files to Outlook 2010 contacts? I've downloaded the BCM Database Tool but that doesn't seem to have fixed the issue. Any help would be much appreciated.
Squire4Hire
Is there any reason why you couldn't install BCM 2010 and connect to the BCM 2007 server to collect those contacts? This link should send you in the right direction to download it.
Aside from that, I'm not sure you'd be able to access the BCM 2007 server easily to retrieve those contacts.
trmiller21
Aside from that, I'm not sure you'd be able to access the BCM 2007 server easily to retrieve those contacts.[/QUOTE
Thanks, that worked. I had to download BCM for Outlook 2010 and then synchronize the files with the exchange.
B Creating an Offline Database with Outlook 2007 BCM Using Outlook 1
V Outlook 2007 BCM restore after removal Using Outlook 6
J not enough memory in outlook 2007 after installing bcm Using Outlook 2
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
K Marketing Campaign will not launch using Outlook 2007 with BCM Using Outlook 3
K Marketing Campaign will not launch with Outlook with BCM 2007 Using Outlook 1
D Moving from Business Contact Manager for Outlook 2007 to BCM 2010 Using Outlook 1
M Adding BCM to Outlook 2007 BCM (Business Contact Manager) 1
F Outlook 2007 BCM Exporting Files BCM (Business Contact Manager) 2
L How do you Recover from An Outlook 2007 & BCM Crash BCM (Business Contact Manager) 1
A Add BCM to outlook 2007 BCM (Business Contact Manager) 1
C Error when installing BCM for outlook 2007 from disk 2 BCM (Business Contact Manager) 3
B Outlook 2007 BCM will not recognize data files BCM (Business Contact Manager) 1
J BCM 2007 Shutting Down Outlook BCM (Business Contact Manager) 2
P Windows 7 / Outlook BCM 2007 Stability BCM (Business Contact Manager) 1
N Outlook 2007 w/BCM - Email issues BCM (Business Contact Manager) 5
N Email issues since installing BCM with Outlook 2007 BCM (Business Contact Manager) 1
M Outlook 2007 with BCM - Tasks being created automatically BCM (Business Contact Manager) 1
D Outlook 2007 BCM - Win 7 BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
A Outlook 2007 ca+n't find bcm BCM (Business Contact Manager) 1
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
H How to get BCM in OUtlook 2007 on Vista to detect my MDF file? BCM (Business Contact Manager) 1
D Outlook 2007 BCM SQL server problem BCM (Business Contact Manager) 1
D Outlook 2007 + BCM & SP2 - windows7 ? BCM (Business Contact Manager) 6
K Is it possible to use BCM 2003 with Outlook 2007? BCM (Business Contact Manager) 4
R BCM 2007 no longer showing up within Outlook 2007 BCM (Business Contact Manager) 3
P Outlook 2007 with BCM - Out of Memory BCM (Business Contact Manager) 13
M Outlook 2007 crashes with BCM BCM (Business Contact Manager) 1
K Moving data from Outlook 2007 to Outlook 2007 with BCM BCM (Business Contact Manager) 3
B BCM freezes Outlook 2007 BCM (Business Contact Manager) 3
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
L Outloook 2007 Ultimate BCM and Outlook Contacts? BCM (Business Contact Manager) 6
M BCM 2007 Can't find SS2012Express Using Outlook 2
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
J No errors from BCM 2007 but can't see database BCM (Business Contact Manager) 0
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
E BCM 2007 no reminder visible at client PC in workgroup BCM (Business Contact Manager) 5
U TABS MISSING OR DUPLICATED - BCM 2007 on Vista laptop BCM (Business Contact Manager) 5
J Unable to view History items in BCM 2007 shared database BCM (Business Contact Manager) 3
J BCM 2007 Cannot Connect to Shared Database Using Outlook 1
P Attempt to fetch logical page in database failed: BCM 2007 Using Outlook 1
M BCM 2007 compatibility with Mobile 6.5 Using Outlook 1
R BCM 2007 to 2010 Conversion fails - Database size > 4GB Help! Using Outlook 1
J BCM 2007 - Opportunities task uses wrong form Using Outlook 1
D Linking Emails BCM 2007 Using Outlook 1
C BCM 2007 to 2010 Migration BCM (Business Contact Manager) 1
