Send/receive getting stuck
johnhoward72
I have a new computer (Windows 7, 64-bit) that is running 32-bit Outlook 2010. I have downloaded the Hotmail connector (also 32 bit), but the synchronisation isn't working properly. When I did the initial connection it was fine. However, when I tried to connect a few days later, no new emails get downloaded. I deleted the account and reinstalled. It connected and downloaded about half of my messages, but it has now stopped downloading anything further.
I am able to send Hotmail emails from Outlook, so I know it's connected to the server somehow. However, I can't receive anything in Outlook (though I do receive things in the web version of Hotmail), so something isn't right.
Any suggestions?
Many thanks,
John
When did you last delete the account from outlook? I wonder if this is the bug FIX they started rolling out yesterday. Outlook didn't sync right and only downloaded newish mail. Then each time it downloaded more of the old mail. Other users reported they needed to remove the account and re-add it for the fixed sync to work.
H Getting send and receive (0x800408fc) error in outlook 2003 with windows Using Outlook 2
D getting error 0X80040600 when trying to send and receive emails in Outlook 2007 Using Outlook 4
H Send Receive Error getting password prompts Using Outlook 1
P Outlook 2010 Constantly Getting Stuck During Send/Receive of IMAP Account, Not Getting Emails Automa Using Outlook 13
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
Diane Poremsky Configuring a Manual Send and Receive in Outlook New Slipstick.com Articles 0
M configure Onpremise exchange to send/receive emails internally and externally) Exchange Server Administration 0
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
J Send and Receive Button - only check default account? Using Outlook 1
S send/receive issues outlook 2013 Using Outlook 4
W OUTLOOK 2007 FREEZES. WILL NOT SEND NOR RECEIVE Using Outlook 1
Z Always Send from Default Account, depend of receive account Outlook VBA and Custom Forms 7
wisedave Office 365 Outlook - Emails send but don't receive Using Outlook 12
D Outlook 2010 hangs during message send/receive Using Outlook 2
Nesher Can send but not receive Using Outlook 1
David Trevose Hanging on Send Receive Using Outlook 2
mikecox "Send/Receive" goes missing Using Outlook 3
R Email Send & Receive Turned off but sends automatically anyway Using Outlook 1
N Outlook 2010 take long time in send / receive Using Outlook 1
J why won't the automatic send/receive work Using Outlook 7
A Auto send-receive in Outlook not working Using Outlook 6
R send/receive no action Using Outlook 2
A yahoo mail doesn't send or receive reliably Using Outlook 1
E Strange Send/Receive count Using Outlook 3
Jennifer Murphy Why would I want to send/receive when offline? Using Outlook 0
S Send/Receive Progress is black??? Using Outlook 4
M Send receive Progress Box Using Outlook 4
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
A Send only, don't receive Using Outlook 1
K Send/Receive All Folders doesn't show Progress status Using Outlook 14
H Send/Receive Error Sending E-Mails Using POP3 GMail Account Using Outlook 2
J Correct settings for send/receive groups w/Exchange Using Outlook 3
T Changed password now can't send/receive Using Outlook 1
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
X Send & receive takes SO LONG Using Outlook 1
P Send/Receive error in Outlook 2007 Using Outlook 2
W Send/Receive status bar Using Outlook 0
O two profiles send/receive from different servers Using Outlook 1
S Error code 0x8004102A Error With Send/Receive Using Outlook.com accounts in Outlook 2
S Connector Forces Outlook 2007 To Hang On Send/Receive Using Outlook.com accounts in Outlook 3
L Send/receive error (0X800CCC80) Using Outlook 2
B Send/Receive Status in Outlook 2010 Using Outlook 2
