Messages stay marked unread
bright75
I am using Outlook 2003 and recently messages I receive in my Inbox stay marked unread (bold) even after opening them. Any suggestions on how to change this back? I used to just click on the message and it was no longer bold.
larry
Right click anywhere on the row of field names above the message list and choose Custom (or Customize) at the bottom. You can either click Reset to reset the view or look at the Automatic formatting settings - did you create a formatting rule that leaves the messages bold?
bright75
Thanks! I tried resetting and it still did not fix the problem. We have not created any new formatting rules. It's so weird because it just started keeping all the messages bold. Any other ideas?
Thanks for you help!
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
B IMAP server rejects sent email - cannot deliver messages Using Outlook 2
J Deliver new messages to New or Existing Data File? Using Outlook 2
M Messages Intermittently Dont Arrive In Sent Items After Sending Successfully Using Outlook 4
R Why doesn't outlook use "Normal" style for new messages? Using Outlook 4
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
T SMTP messages stuck in Outbox Using Outlook 0
Mark White VBA to deal with Recalled messages Outlook VBA and Custom Forms 7
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
Diane Poremsky Save Messages and Attachments to a New Folder Using Outlook 0
P AOL messages Outlook VBA and Custom Forms 0
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
I Identify Number of email messages opened Outlook VBA and Custom Forms 7
Diane Poremsky Monitor secondary mailbox folder for new messages Using Outlook 0
Diane Poremsky After viewing the Outbox, messages won't send Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
Diane Poremsky Remove Attachments From Messages Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
S Outlook 2013 doesn't download html messages Using Outlook 0
