Outlook 2010 Daily Calender need high detail
raffrobb
Is there a way to see the daily view in high detail similar to monthly high detail and Outlook 2003 daily view with defaulted to high detail.
Robb
raffrobb
The 2003 daily view is same as 2010 monthly view in terms of the text display in appointment and meeting boxes.
High detail is shown, i.e. blue text for times.
Robb
