OUTLOOK 2000, Need Help !
Bubey
I'm still using it without Outlook. Has anyone found a way around it so that I could use my Outlook program ?
Is it possible to copy the PST file from my XP installation to my newer laptop that has Vista? Would this make the
Ofc 2000 Outlook program work for e-mails ? nneldred@tampabay.rr.com Thanks in advance for the help.
P.S. Sure miss the MS User Groups.....They were such a help and in my younger days I used to answer questions
for some of the now MVP's.:(
You can copy the data file (pst) to vista - outlook 2000 is "not suppoorted" - for the best experience, you should install it in Corp mode.
See Outlook on Vista and Windows7 for some information on it and workarounds if you want or need to use internet mode.
M which Outlook recommended to buy for moving Outlook 2000 versions Contact Data Using Outlook 2
B Outlook 2000 Rule to Move txt msg Not Working if size >24KB Using Outlook 3
D Outlook 2000 slow Using Outlook 2
T How can I eradicate Outlook 2000+ Using Outlook 6
T passwords in outlook 2000(in XP Virtual PC mode) under Windows 7 Professional Using Outlook 6
P Printing problems with MS Outlook 2000 Using Outlook 1
B Restoring Outlook 2000 messages Using Outlook 4
B strange change in Outlook 2000 forms Outlook VBA and Custom Forms 1
J Outlook 2000 "My Shortcuts" question Outlook VBA and Custom Forms 2
J Outlook 2000 Message stuck in Outbox Outlook VBA and Custom Forms 6
S Choosing different reply template in Outlook 2000 Outlook VBA and Custom Forms 1
R IConverterSession::MAPIToMIMEStm error in outlook 2000 Outlook VBA and Custom Forms 3
R IConverterSession::MIMEToMAPI error in outlook 2000 Outlook VBA and Custom Forms 1
M Issue transferring Outlook 2016 email accounts & settings onto new computer Using Outlook 2
S Excel vba code to manage outlook web app Using Outlook 8
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 0
D Connecting Gmail to Outlook 365 - My Setup not working Using Outlook 1
K Outlook tasks formatting Using Outlook 4
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
H I have no profile listed for Outlook! Using Outlook 9
D Outlook 2016 how to use gmail account as source account for outlook 365 Using Outlook 9
Horsepower Contacts added from iPhone don't show up in Outlook Using Outlook 1
A Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
L Outlook saved template function too limited Using Outlook 2
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
witzker Open Contact missing in Outlook 2019 Using Outlook 2
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
