starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filtering'
cagilbert
starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filtering'.
I can change it to Low or High, but when I exit and restart Outlook it's back to none. This just started happening after years of use.
bamix_o
Re: starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filteri
Have there been any updates on this issue ? I now have a similar problem with OL 2007 and POP3 accounts. I can't be sure but it seemed to cooincide with a program update of Avast Antivirus recently. I just noticed late last week that my Junk e-Mail Folder was not being added to (I check and clean out every day) and going to Tools/Options I found that the filtering was turned off. Thinking it was just one of those things, I reset it back to "Low" and went about my business. The next day I started to get more spam coming through without the Junk e-Mail Folder catching anything. So I checked the status again and it was turned back to Off. I reset it to High and closed the pop-up menu, opened it again and it was still at High. So then I closed OL and then restarted it and checked and it was turned to Off again. I seem to be getting a lot of spam from SP Casino too that I wasn't getting until recently. I have checked the Avast settings and there is nothing that specifically covers this. What else could I be looking for ? Could I have received a virus without it being identified ? If anyone has any comments they would be appreciated.
bamix_o
Update: Yes, it seems that there is an Avast 'anti-spam' add-in at play. Going to Tools/Options and selecting Trust Center, I selected Add-ins and found "avast! Antispam" was active. Then I checked the box 'Apply macro security settings to installed add-ins' and restarted OL. If I enable the Avast add-in at OL start up then my Junk e-Mail setting is turned to Off from whatever status I left it at. If I disable the Avast add-in at OL start up then my filter setting remains where I left it prior to closing OL. Hope that this helps somebody.
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
S Setup many personal calendars on outlook 2013 on new laptop- starting over Using Outlook 1
B Starting up outlook in Windows 8 Using Outlook 2
K Starting Outlook 2013 x64 minimized in Win 8 with or without Task manager Using Outlook 5
D Starting Outlook 2K3 without e-mail support Using Outlook 4
S Starting outlook in imap Inbox Using Outlook 7
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
N Starting out with BCM - Customizing contact records BCM (Business Contact Manager) 1
V Starting Fresh with a new PST file. Using Outlook 0
T Click "A" to see all email from people with names starting with A... etc Using Outlook 3
J Problems starting Information Store Server in Exchange 2003 Exchange Server Administration 13
C Starting out and would like advice Outlook VBA and Custom Forms 1
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 2
@ Outlook Using Outlook 2
