Printing, pasting & deleting issues
Partsboss
I recently updated to Outlook 2010 and I am experiencing several frustrations.
I receive invoices via e-mail which I print and then process. When I print them the header prints along with the invoice. Is there a way to print the invoice without the header, or shrink the header and invoice to only print on one page?
I recently copied information from an e-mail and attempted to past it into a task. When I attempted to save the task it would not save, stating that I didn’t have the permission to save some of the information in my paste. What settings do I need to change?
I am finding that Outlook e-mail is not deleting e-mails. In the “old” edition I would highlight one or several e-mails and click “delete” and they were gone. Now I have to do one at a time, and they don’t always seem to be deleted. What settings do I need to change?
Thanks for your help.
(hate the mobile app... can't read and reply at once :( ) -
on deleting, what account type is configured? it should work the same on outlook 2010 as it did before. i don't think the task problem is related.
the task problem may be related to controls - i'll check that when i get back on my laptop. it should not kick up that message but may if there is something in the code, like activex.
Partsboss
Under Options, Mail, then what should I look for? to print just the body?
Thank you,
You need to open the message and on the More > Actions button is Open in browser. Then print from the browser. This assumes the message is HTML, not RTF. If its RTF or plain text, you'll need to convert to HTML using Edit message command first - obviously not a good option - but that is the only way to remove the section the says
Account Name
<underline
To/From/subject/Date
None of that is editable. In Outlook 2003 you could get past some of the problems by using word as the editor and clicking forward - actually, that might help you some in Outlook 2010. (I'm on a mobile device and can't verify what all is included when you print a forward in outlook 2007/2010)
A How to use calender printing? Calendar Printing Assistant 1
M Printing Appointments Using Outlook 1
M Calendar daily Appointments and printing Calendar Printing Assistant 0
T Printing from Outlook is now defaulting to "Shrink to Fit"! Using Outlook 5
snissen Printing foreign language messages Using Outlook 1
L printing contacts Using Outlook 1
A How to get rid of Contacts field when printing emails? Using Outlook 0
Diane Poremsky Printing Calendars with Color Categories New Slipstick.com Articles 0
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
D Printing Contacts Using Outlook 2
C Printing tasks with multiple categories Using Outlook 5
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
S macro for opening attachments and printing Using Outlook 1
J Printing Mulitple Calendars Outlook VBA and Custom Forms 1
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
G booklet printing in outlook 2007 Using Outlook 1
W Meeting printing background fields Using Outlook 0
K calendar printing Using Outlook 1
M Outlook 2013 is printing headers only Using Outlook 4
S So Disappointed in Calendar Printing Assistant!! Calendar Printing Assistant 2
D Printing Attachments Automatically in Outlook 2010 Using Outlook 1
F Printing all day events only Calendar Printing Assistant 3
J outlook printing Using Outlook 2
J Printing Calendar in Outlook 2013 Using Outlook 0
C Printing Outlook Form Controls via Word Using Outlook 11
E Printing Using Outlook 1
C Custom .oft / Printing Issue(s) Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
P Printing Issues in Outlook 2007 Using Outlook 1
E Outlook 2010 network printing problems Using Outlook 4
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
I Printing Using Outlook 0
E Monthly Style Calendar Printing Using Outlook 6
S How to remove tracking from printing - outlook 2010 Using Outlook 4
P Printing calendar (work week) with numerous (i.e. >7) all day events... Calendar Printing Assistant 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Calendar Printing Assistant 2
E Adding Start and End Time to Daily View in Calendar Printing assistant Calendar Printing Assistant 1
M Outlook 2010 task line printing Using Outlook 1
S Printing Selected Date Range in Monthly Style Using Outlook 1
S Does Printing Assistant Work with Windows 8 and Office 10? Calendar Printing Assistant 1
A outlook printing assistant Help editing template Calendar Printing Assistant 3
S Printing Category Key on Calendar Using Outlook 1
P Printing Issue on Calendar Printing Assistant Calendar Printing Assistant 0
W Calendar Printing with Outlook 2010 (64 bit) Calendar Printing Assistant 1
R printing fields in addresses Using Outlook 1
S Nor printing to Epson printer Calendar Printing Assistant 3
