Trying to connect to exchange
Annie P
Outlook 2007
Upgraded to Outlook 2007 from Outlook 2003. After upgrade problems began. Outlook will be connected and lose its connection and a message will appear in the bottom right hand corner stating "Trying to connect to Microsoft exchange". It will sit there and eventually disconnect you from the server. The only way to correct the problem and reconnect to the server is to close the program and disconnect the internet modem and reboot the modem. Any suggestions on what maybe causing the problem?
Did you make a new profile? I'd try that first.
You can also ctrl+right click on the outlook icon in the tray and choose Connection status. It might not be much help, but you can 'watch' the disconnects and see if one area is the problem.
Annie P
Outlook 2007
I can not create a new profile. I am operating on a company pc. When Outlook goes down, we can access the internet and visit any website, but the Outlook application will not work nor will the web access site. When attempting to access the web access internet site you get a message stating the page can not be displayed, but google or any other website can.
So you are using online mode. Are you the only one affected or do others also have a problem?
Oh wait, you say when Outlook is offline, you can't access it using OWA either? That sounds like something on the server side, not on the client side.
The admin needs to check the server logs for clues, but one possible issue could be this - http://support.microsoft.com/kb/2019948 - however there are many others possible causes too.
D Outlook "Trying to Connect" Exchange Server Administration 1
D Error trying to connect to database on the server BCM (Business Contact Manager) 1
M outlook 365 trying to finish my sentences Using Outlook 0
O The page that you are trying to access cannot be loaded. Using Outlook 0
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
KURTiS MAXiMUS Trying to appactivate ERP window Outlook VBA and Custom Forms 16
R Trying to extract information between two symbols from outlook subject Using Outlook 2
Danie Lawson Trying to recover calendar Using Outlook 4
L Trying to open contacts pst. file in outlook 365 Using Outlook 3
L Trying to check for the absence of mail. Outlook VBA and Custom Forms 1
D Trying to repair Outlook rules Using Outlook 5
S Outlook 2010 trying to default Data file to outlook.com calendar Using Outlook 6
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R Trying to sync my Outlook email on iphone Using Outlook 1
A outlook trying to keep sending Using Outlook 1
P Trying to add subject and name to an email using VB Code Using Outlook 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
P Outlook works, but freezes when trying to use calender v2007 (vista prof) Using Outlook 1
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
P Trying to get 'Calendar Name' to appear like 'Subject' and 'Location' in event Calendar Printing Assistant 0
S Trying to have a prompt to ask for text to be added to subject before sending. Using Outlook 3
K Wont send or recieve now with new server keeps asking for password when trying Using Outlook 1
P Word experienced and error trying to open the file Using Outlook 2
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
D Outlook 2003 - A program is trying to access e-mail addresses Outlook VBA and Custom Forms 5
S Trying to create a UPS from Outlook VBA and Custom Forms 2
T Trying to start Outlook from VBA or VBS not working. Outlook VBA and Custom Forms 4
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
A Error: 3033 when trying to OpenDatabase using DAO Outlook VBA and Custom Forms 3
U Recovered PST file "Cannot move item" error when trying to move e- Using Outlook 6
D Trying to reconnect BCM databases in Outlook 2003 BCM (Business Contact Manager) 1
A Connect to server to views items Using Outlook 0
Jennifer Murphy Outlook can't connect to Office 365 at resort hotel Using Outlook.com accounts in Outlook 1
T Cannot connect to main BT email account, sub accts okay Using Outlook 0
W Cant connect to outlook.com from outlook Using Outlook.com accounts in Outlook 2
C Connect VBA(outllok) with JavaScript Outlook VBA and Custom Forms 1
T Outlook 2016 cannot connect after transition to Outlook Mail Using Outlook.com accounts in Outlook 4
Diane Poremsky Direct Connect to Office 365 New Slipstick.com Articles 0
Diane Poremsky Connect Gmail Calendar to Outlook New Slipstick.com Articles 0
