Thousand of sync issues on Outlook clients with Exchange 2010
robertin75
Outlook 2007
Hello:
I was checking the sync issues folder on several Outlook PC's and some of them have thousand of issues mostly on the Sync Issues root folder location.
Are these normal?
Some examples:
9:18:05 Error synchronizing folder
9:18:05 [80070005-508-80070005-560]
9:18:05 You do not have sufficient permission to perform this operation on this object. See the folder contact or your system administrator.
9:18:05 Microsoft Exchange Information Store
9:18:05 For more information on this failure, click the URL below:
9:18:05 Support For Microsoft Outlook9:18:05 Error synchronizing folder
-----------------------------------------------------------------------------------------------------------10:43:28 Error synchronizing folder
10:43:28 [80070005-508-80070005-560]
10:43:28 You do not have sufficient permission to perform this operation on this object. See the folder contact or your system administrator.
10:43:28 Microsoft Exchange Information Store
10:43:28 For more information on this failure, click the URL below:
10:43:28 Support For Microsoft Outlook
------------------------------------------------------------------------------------------------------13:13:26 Synchronization of some deletions failed.
13:13:26 [8004010F-501-8004010F-130]
13:13:26 The client operation failed.
13:13:26 Microsoft Exchange Information Store
13:13:26 For more information on this failure, click the URL below:
13:13:26 Support For Microsoft Outlook
13:13:26 1 item(s) deleted in online folder
13:13:26 Done
-------------------------------------------------------------------------------------------------------9:36:36 Synchronizer Version 14.0.6117
9:36:36 Synchronizing Mailbox 'Donna'
9:36:36 Synchronizing server changes in folder 'Ron - Calendar'
9:36:36 Downloading from server 'MAIL.vcs.local'
9:36:36 Error synchronizing folder
9:36:36 [80070005-508-80070005-560]
9:36:36 You do not have sufficient permission to perform this operation on this object. See the folder contact or your system administrator.
9:36:36 Microsoft Exchange Information Store
9:36:36 For more information on this failure, click the URL below:
9:36:36 Support For Microsoft Outlook
9:36:36 Done
-------------------------------------------------------------------------------------------------------------Anyone can shed some light?
Thanks and help is greatly appreciated.
sorry about missing the question before. Sync errors are not unusual but these errors are saying you don't have permission to the folder.
Can donna open ron's calendar using open shared folders?
robertin75
Outlook 2007
Actually she does.
I also have a lot of sync issues on my outlook from calendars I have permissions to open. I get sometimes 4 of these errors per day.
Could this because the Exchange Server does not have the latest SP?
http://support.microsoft.com/kb/221238</SPAN>
This is apparently a different error code but I don't know if this applies also to the problem we are facing.
This is the current version of the Exchange Server 2010 we have:
Version 14.01.0355.002
Thanks for your help
That KB references Exchange 5.5 and old versions of Outlook - but in theory, the problem could be the same. Are you guys using public folders on Exchange 2010?
Does OWA work ok? Anything in the Event logs on the server? I'm wondering if permissions on EWS are goofy and causing the error.
epyxken
I get this stupid message every-time I try to sync a calendar for someone who has a private appointment!
Calendars re-sync a lot of times in a day.
Looks like a bug to me Microsoft!
O Outlook 2016 - two addressbooks - how to sync and which one is in use? Using Outlook.com accounts in Outlook 1
Peter R Hawkes Can I sync VBAProject.otm? Outlook VBA and Custom Forms 1
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
M Mobile notifications and sync in Outlook.com Using Outlook.com accounts in Outlook 2
GregS No contacts sync from Outlook 2016 to Windows Phone Using Outlook 0
GregS Sync contacts Outlook.com to "MS People" mobile Using Outlook 1
Diane Poremsky Outlook and iCloud Sync Issues New Slipstick.com Articles 0
Diane Poremsky Outlook Connector Contact Sync Bug (Fixed) New Slipstick.com Articles 0
H Sync Contacts between Office 365 and Gmail. Exchange Server Administration 3
W FYI: CodeTwo Sync for iCloud is FREE now! Using Outlook 0
S Outlook 2016 Sync issues with outlook.com Using Outlook 0
D Outlook Notes and Exchange Sync Using Outlook 7
A hotmail calendar sync Using Outlook 1
T Sync gmail with Outlook 2016 Using Outlook 5
P Outlook 2013 to Outlook.com Time Zone sync Using Outlook 4
Commodore Two Sync Issues folders Using Outlook 4
Travis Lloyd Will Outlook 2016 Desktop Sync-up With Outlook.com? Using Outlook 8
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
