Outlook 2010 Custom Form Problem
minddesign
Good Day All,
I am having an issue with implementing a Outlook form. I am new to form creation and I think I am missing something. I fill out a similar form longhand and have created this form to cut time. This will only need to be distributed inner office. Everytime I send this via email it comes up as a blank page. Any help would be awesome. I have attached a screenshot of the form.
If this is a coding issue please direct me to where I can grab the snippet of code to fix the problem.
Outlook 2010
larry
I'd suggest the MSDN forum might be better - Outlook for Developers Forum - we can handle simple questions here but I don't do much forms work. I think you either need to publish it in the org forms library or send the form definitions with it. (Or publish it in each users mailbox.) The MSDN experts can tell you exactly.
J Outlook 2010: can't forward appointment on custom form Using Outlook 1
G Custom Form code not working - Outlook 2010 Outlook VBA and Custom Forms 2
S Setting up Outlook 2010 to work with custom domain outlook.com account BCM (Business Contact Manager) 3
P Outlook 2010 custom form olk control font size increases everytime form is published Outlook VBA and Custom Forms 1
S Seeing Custom Fields in Contacts (Outlook 2010) Using Outlook 0
F Outlook 2010 - Need help with a custom field. Using Outlook 3
F Outlook 2010 custom font style duplicates itself every time I save a task Using Outlook 0
C Set reminder time in custom form (Outlook 2010) Using Outlook 1
C Custom Form Outlook 2010 Contacts Using Outlook 3
P Unable to delete custom forms in outlook 2010 Using Outlook 1
C Outlook 2010 Custom Form Issues Using Outlook 2
O Outlook 2010 - How to create custom Group By Arrangements for email Using Outlook 3
M How update database from custom fields in outlook 2010 message Using Outlook 1
