Outlook closes down after clicking on the quick print icon.
Paddy_Bne
I've got a user who intermittenly has this occur to them when printing emails.
When they are on the home screen they highlight an email they wish to print off (HTML formatt) by clicking on it once, they then click on the quick print icon. As it moves to the print screen outlook will close without any error messages appearing. They then re-open Outlook, go back to that email, click on quick print again and this time they can print. As I've mentioned it happens intermittently and on different emails.
We've tried both renaming the outlprnt file to .old and deleting the file. Outlook will create a new outlprnt file but it will still occur the following day. Other users that use the same printer have not had this issue. We are using Outlook 2010, v14.0.6023 (32-bit) SP1 in a Citrix environment.
D Outlook 2003 Saving into a textbox when form closes Outlook VBA and Custom Forms 3
J Outlook closes when accessing History in BCM BCM (Business Contact Manager) 4
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
P How can I stop Outlook 365 duplicating the posts? Using Outlook 2
