Rule to Auto-forward/re-direct a specific incoming email to a group via BCC?
sdgmcdon
I have an email list of subscribers that is constantly changing, adding members/removing members on a per request basis for my business. The list is large enough now that I need to automate the email.
Basically I have an email that comes in once each day, I need outlook to automatically forward that email to the group BCC'd so members of the group do not get the email addresses of other members.
Two problems:
  • Outlook will not forward to the group at all, says it can add the members of the group to the rule, this sucks as it would require me editing the rule each time I have to change members (change the group, then edit the rule to use the new member list).
  • Second problem is this method doesn't allow me to BCC the email.
I have limited access to the exchange server I'm on (Apptix) and was thinking I could just create a distribution list on the server but that's a pain in the butt to constantly edit too (but I think it's the only solution short of VBA code which I would prefer to avoid?).
If I use this method on exchange (distribution list), then I could just tell outlook to forward the email to groupname@domain.com for the email, which I think solves all the problems, but I need to be 100% sure there is no way any member of that group can see other members email addresses? Also, I don't like knowing I have to add each group member to my exchange account as a contact to get them into a distribution list, just seems over-complicated.
Any other way to do it?
Re: Rule to Auto-forward/re-direct a specific incoming email to a group via BC
The server side dl would be the best option but managing it could be a PITA. A run a rule script would be easier - it can set a dl as the bcc address and forward the message when it arrives. See Run a Script Rule: Change Subject then Forward Message | Slipstick Systems for the basics i added the BCC line and it worked:
myForward.Recipients.Add "alias"
myForward.BCC = "dl name"
BTW, you can use either email address or a DL name (or a contact's name) in the code - as long as you have a contact or dl for the name, outlook will resolve it.
R Outlook 2013 VB rule to auto save attachments with different file types Outlook VBA and Custom Forms 5
N VBA, Rule that will Auto Reply based on time of day Outlook VBA and Custom Forms 1
R Auto-reply with rule on shared mailbox Using Outlook 1
Aussie Outlook 365 Rule runs manually but returns the error code "an unexpected error has occurred" when incoming mail arrives Using Outlook 0
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
Ascar_CT Rule behavior analysis - any tools available? Using Outlook 0
Liza Creating a rule in outlook to filter messages Using Outlook 0
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
