VBA Macro Works in 2007 but errors in 2010
DStrange
I have this snippet of code that is giving me problems.
[h=2]On Error GoTo MoveHandler
Box = InputBox("1 for Processed" & vbNewLine & "2 for No Ticket Required" & vbNewLine & "3 To Not Move this Email")
If Box = "1" Then objItem(1).Move objFolder.Folders("Processed")
If Box = "2" Then objItem(1).Move objFolder.Folders("No Ticket Required - E-Mail")
If Box = "3" Then MsgBox ("Your email will not be moved")
In Outlook 2007, this never errored out, I could repeatedly use the macro. In 2010, this will let me move one time to either of the folders, but then will error out saying it cannot find the folders.
Anyone know what changed in 2010 that would cause my macro to not work anymore?
[/h]
DStrange
what is the full macro code? the objFolder is likely the cause of the problem.
Here is the entirety of the code:
Sub Email()
Dim msg As MailItem
Dim i As Integer
Dim objFolder As Outlook.MAPIFolder
Dim objItem As Object
Dim Box As Integer
Set objFolder = objNS.Folders("GSC - DNB_Global Service Center").Folders("Inbox")
Set objItem = ActiveExplorer.Selection
'Assume this is a mail folder
'####change this to your Desktop#######
Const Path As String = "C:\Users\dastra\Downloads\Attachments\"
i = 1
'delete any previous incarnation from this macro
If Dir(Path & "message.htm") <> "" Then
Kill Path & "message.htm"
Kill Path & "message_files\*.*"
'save email as HTML to Path above
Set msg = ActiveExplorer.Selection.Item(1)
msg.SaveAs Path & "message.htm", olHTML
'if attachments exist, save them each in the message_files folder
If msg.Attachments.Count > 0 Then
While i <= msg.Attachments.Count
msg.Attachments.Item(i).SaveAsFile Path & "message_files\" & msg.Attachments.Item(i).FileName
i = i + 1
Wend
'mark email as read
msg.UnRead = False
On Error GoTo EditHandler
Dim DateTime As String
Dim MyInput As String
Dim ToAdd As String
Dim StartBody As String
'#####change this to your initials#####
Const Initials As String = "DS"
'get ticket number from user, date/time from system and add into single string
MyInput = InputBox("Enter I or R followed by ticket number")
DateTime = Now()
If MyInput = "" Then GoTo EditHandler
ToAdd = MyInput & " " & DateTime & " " & Initials
'prepend body of message with ticket/date/time/initials
StartBody = msg.HTMLBody
msg.HTMLBody = ToAdd & "<br><br><br>" & StartBody
' Clean Up
Set msg = Nothing
Set objFolder = Nothing
Set objNS = Nothing
Set objItem = Nothing
SaveHandler:
MsgBox ("Save as HTML Failed.")
EditHandler:
MsgBox ("Save Successful, but failed to edit with ticket #.")
MoveHandler:
MsgBox ("Save and Edit Successful, but move failed")
It will never error on that top code of :Set objFolder = objNS.Folders("GSC - DNB_Global Service Center").Folders("Inbox")
however if I do Set objFolder = objNS.Folders("GSC - DNB_Global Service Center").Folders("Inbox").Folders("Processed") sometimes it will work for 10-20 uses of the macro, sometimes it will work for 1 use of the macro before I need to restart Outlook.
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 8
