Exchange 2003, NDR, DNS problems
Outlook 2007
I have been dealing with lots of NDR's for example the following:
blahblahbla on 10/8/2012 3:13 PM<O:p></O:p>
You do not have permission to send to this recipient. For assistance, contact your system administrator.<O:p></O:p>
<OURDOMAIN.COM#5.7.1 font << 5.7.1 smtp;554>theiremail.com>: Relay access denied
I wasn't the one who setup our Exchange Server and I've been trying to decifer it. Would someone be willing to troubleshoot this for me or even possibly fix it for me? I
You are getting this for all outside addresses? If you get this for all addresses, it's a configuration on your server; if only one domain is affected, it is on their end.
What version of Exchange server do you use? Assuming all mail is bouncing, I think the steps are identical for both Exchange 2010 and 2007, but it's nice to know, just in case they are not.
Outlook 2007
There are certain mail servers that block me. Some go through some don't. It's kind of hit and miss. So I can't figure it out. Lately its been getting worse.
B Exchange 2003 EDB corrupt Exchange Server Administration 6
A Exchange 2003 how to stop accepting EHLO and AUTH commands Exchange Server Administration 2
A Rename resource Exchange 2003 Using Outlook 2
R Exchange 2003 to 2013 mail Exchange Server Administration 4
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
K clear categories on Exchange 2003 & Outlook 2003 Exchange Server Administration 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
O Exchange 2003 displaying HTML emails as having attachments Exchange Server Administration 7
S How to leave e-mail on Exchange 2003 server? Exchange Server Administration 1
J Problems starting Information Store Server in Exchange 2003 Exchange Server Administration 13
J I use Windows XP with Microsoft Outlook 2003 and I cannot get int the Microsoft Exchange server. Using Outlook 1
B Move mailbox from Exchange 2003 to 2010 Exchange Server Administration 2
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
K on outlook 2003, how do I set up an out of office reply if I do not use the exchange server Using Outlook 2
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
S exchange 2003 org to exchange 2010 org Exchange Server Administration 2
T Outlook 2003 thinks I'm connected to and exchange server. I'm not. How do I reset Using Outlook 1
H Unable to remove the last exchange 2003 server in the organization Exchange Server Administration 2
M Inbox is not syncing correctly between OWA and Windows 7 Client with Exchange 2003 Using Outlook 4
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
C Outlook 2003 (or Exchange 2003): Automatically coptying someone on outbound email Using Outlook 2
C Mail folder permissions Exchange 2003/Outlook 2003 Using Outlook 1
M Outlook Mail Format Options - Grayed out 2003 office/outlook in exchange 2007 mail organisation. Using Outlook 3
A I have purchased a replacement computer and installed Outlook 2010. My server is a 2003 small business exchange server. How can I access the calenda Using Outlook 1
M Exchange 2010 Outlook Web App via Exchange 2003 Front End Server Exchange Server Administration 1
J Exchange server 2003 to 2010 Exchange Server Administration 1
L Exchange 2003 to 2010 Migration - Public Folder Replication Failed - Busy/Free Issue Exchange Server Administration 8
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
B Entourage and Exchange 2003 SP2 Using Outlook 1
D Unable to search contacts in Outlook 2003 - Exchange 2010 Using Outlook 2
I Win 2003 AD Exchange 2003 upgrade Exchange Server Administration 6
D Users migrated from exchange 2003 cannot manage Distribution lists from Outlook Exchange Server Administration 7
J Understanding Exchange 2010 <-> Exchange 2003 Connectors....help... Exchange Server Administration 4
W Outlook 2010 Free/Busy Data not updated\viewable - Exchange 2003 SP2 Using Outlook 2
D Exchange 2003 to Exchange 2010 mail stuck in Exchange 2003 Local Delivery Queue Exchange Server Administration 10
S garbage mail recieved from Exchange 2010 HUB to Exchange 2003 user. Exchange Server Administration 2
I Copying mailboxes from Exchange 2003 to Exchange 2010 Exchange Server Administration 3
