pasting text in body of calendar events
oschepps
Outlook 2007
so all of a sudden I can no longer cut and paste text or basically anything into the body section of a calendar event. The large area below the "start" and "end" times.
I've never had this issue before and have been using this version of outlook 2007 for at least 3 years.
Help!!!
oschepps
Outlook 2007
First, Control-V does work so thank you very much!
Still, I've lost all the "other" functionality that I am used to such as "right clicking my mouse" and seeing all the options to cut/copy/ and I can now no longer "paste" a file into the area so I still can't do what I am used to doing.
To answer your question, I don't really use iCloud to manage my email. I do use iCloud to integrate my outlook and iPhone calendars...and I did literally just update my iPhone to IOS6 today. Do you think there is a connection?
thanks!
Yes, there is a connection - it's because of icloud.
I only recently made the Ctrl+V connection - people were complaining that they couldn't paste in calendar & contacts in iCloud2 and every time i tried it, it worked. I was scratching my head over what was different in my setup, was it where i made the appointments etc... i finally figured out it was because I use Ctrl+V.
I have more 'gotchas' here - Outlook and iCloud 2: What you need to know - Slipstick Systems
You could uninstall icloud2 and install icloud1 if the missing features are important to you, however, iCloud1 has quirks of its own.
oschepps
Outlook 2007
Thanks again for you help. The functionality is important to me because I regularly cut and past attachments from other emails into the calendar event and while I can still attach a file I would have to everytime I wanted to attach a file first "save" the file in a folder just to paste it into a calendar event. Big workaround for something that was literally a 1 sec task.
So if I uninstall iCloud2, I'm not sure even where to find iCloud1 and I'm also concerned that everything else will fall apart. My syncing of my other Apple devices that are now updated to IOS6. I love the apple products but they make life hard sometimes!
Any advice?
I have a copy of the iCloud 1.1 if you can't find it at apple. At some point they will either remove their download or force everyone to iCloud 2, but for now it works.
I didn't test it extensively, but i had no problems switching to iCloud 1 and did not notice any immediately problems. Well, one - i needed to delete the iCloud data file and let it rebuild it.
W how do I control the font used when pasting text into an Outlook 2007 email message Using Outlook 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
P Printing, pasting & deleting issues Using Outlook 4
B Font for rows and columns is changing in Outlook message when pasting data from Excel Using Outlook 1
B Font is changing in Outlook message when pasting rows and columns from Excel Using Outlook 2
M MS Outlook 2010, 2 questions, 1 about pasting and 1 about sending Using Outlook 1
J pasting in an email message Using Outlook 2
J Pasting into Outlook 2003 produces blue question mark Using Outlook 2
M Pasting from Clipboard does not create attachment in Outlook 2007 Using Outlook 9
S Body text of Email from invite date/time Outlook VBA and Custom Forms 8
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 3
S Outlook to check for specific text Outlook VBA and Custom Forms 3
B Paste formatted text (bold, underlined and in quotes) Outlook VBA and Custom Forms 1
N Is there an Outlook tool to normalize text for entries that are in ALL CAPS? Using Outlook 2
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
W Message Text Using Outlook 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
J Marco in search of text in subject line Using Outlook 8
M attached images not showing in text area Exchange Server Administration 0
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
P Can't see full text in From and Subject line Using Outlook 1
S Creating Email - Selecting Pre-Defined Text Using Outlook 2
D Delete selected text from incoming emails Outlook VBA and Custom Forms 25
Diane Poremsky Outlook VBA: Use a Text File to Populate a ListBox New Slipstick.com Articles 0
B Importing Text from Excel to Outlook 2013 Calender Using Outlook 0
