Assigned Categories keep getting deleted in mail, bug? How to fix if possible?
mrje1
Hello Everyone,
I am using Outlook 2010 on Windows 8. Here is my issue. I assign all my emails with a specific category. I am not sure how much later, but Outlook removes the categories that are assigned to the emails. I spent quite a bit of time getting all my emails organized this way and is a bit frustrating to have all my hard work erased. The Categories are still located in the category list though. Is this a common bug? If so, how do I get this fixed?
I do appreciate your help. Thank you very much.
Re: Assigned Categories keep getting deleted in mail, bug? How to fix if possi
This is with a pop3 account? I've seen it happen with outlook connector and imap accounts. Neither supports categories so they get wiped out after a couple of syncs.
mrje1
Thank you Diane for your help. Yes, I am all set up with pop3 accounts. I have 7 email accounts hooked up. Also, I would like to add that I automatically assign categories via rules for incoming mail as well.
mrje1
Ok, I figured out the culprit. I have rules set up and by mistake I found out what was going on. In the Run Rules Now Dialog, I had every rules selected including the culprit (Clear Categories on Mail recommended) When I pressed Run Now, it wiped out all the categories, but once I removed the selection from the Clear Categories option and pressed run now, it all came back and now it is not being deleted any more. Will see if it continues to be fine over time. So, if I was wrong, I will re-post here.
Thank you for your help Diane.
Cool. Thanks for the update.
mrje1
Your welcome. Enjoy your evening.
F How to show assigned tasks under certain mailbox? Using Outlook 4
C Changing Domain -- Assigned To User field Migration? BCM (Business Contact Manager) 1
D Macro to export mail data based on assigned category Using Outlook 3
A Can Rule Check Category Contact is assigned? Using Outlook 1
P Can't Add User to Assigned to List in a Shared BCM2010 BCM (Business Contact Manager) 2
D Cannot Save Assigned Access Rights To Delegates for Allowing Another User To Manage the Calendar and Contacts Using Outlook 2
A Assigned as editor and deleting a meeting planner in outlook 2010 Using Outlook 3
T Updates on Tasks Assigned to Multiple People Using Outlook 1
J When I send an item with a Category assigned, the Category doesn't stick Using Outlook 4
D How to Get Updates for an Assigned Task in a Shared Tasks Folder? Using Outlook 6
K Set "Assigned To" for a Contact Item Outlook VBA and Custom Forms 5
P Custom Task Cannot be open when assigned. Outlook VBA and Custom Forms 7
S reminder for assigned tasks Using Outlook 5
C Accessing _RecipientControl1 (Assigned To) Outlook VBA and Custom Forms 2
O Calendar - appointment templates and categories Using Outlook 1
T Increasing the number of items that appear on the Categories list Using Outlook 2
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
B How to show concatenated categories in list task view? Using Outlook 2
A Outlook reverse categories Outlook VBA and Custom Forms 1
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
P Task Categories Using Outlook 2
I categories for outgoing email Outlook VBA and Custom Forms 7
S Appointment colour categories disappear Using Outlook 4
Z Outlook.com Contact categories Using Outlook 8
Diane Poremsky Using Categories for Dynamic Distribution Lists New Slipstick.com Articles 0
Diane Poremsky Printing Calendars with Color Categories New Slipstick.com Articles 0
avant-guvnor Outlook 2016 and views, categories etc. Using Outlook 3
T categories in Outlook 2016 Using Outlook 0
makinmyway How to Easily/Quickly Ungroup by Categories Using Outlook 1
C Printing tasks with multiple categories Using Outlook 5
Mark Foley Where are Outlook categories save for IMAP? Using Outlook 12
T Outlook 2007 adding categories Using Outlook 15
E Outlook 2013 is stripping out categories on sent meeting invites Using Outlook 0
Karlski Deselecting categories often takes 3+ attempts Using Outlook 3
Diane Poremsky How to Upgrade to Color Categories New Slipstick.com Articles 0
K Missing Categories & Colors Using Outlook 5
Diane Poremsky Create a list of color categories and merge or restore the list using VBA New Slipstick.com Articles 0
