Outlook Invites automatically adding 'Required Attendees'
Jen
My Outlook invites are adding as 'Required' people that I did not 'invite' to attend. These turn out to be people who may have 'Viewing/Scheduling ' rights on the calendar, which means they would receive automatically the invite as 'Optional' , right? Somehow they are being included in the 'Required' category, which is causing a lot of confusion.:confused: Could this be a Settings issue? Thanks!
Did these people set up the meeting on your behalf? If they only have permission to view or create a appointments, they should not be added to all meetings. If they are your delegates, they could be added.
Go to Tools, Options, Delegates - are they listed there and what are their permissions?
If they aren't delegates then something else is causing it - a custom form, something on the server, rules... (the last two would add the names after its sent).
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Using Outlook 2
A Multiple Outlook Invites Received by One Person Using Outlook 4
E Outlook 2013 is stripping out categories on sent meeting invites Using Outlook 0
P Change the Outlook.com "from" address for calendar event invites Using Outlook 9
A Outlook 2011 forwards calendar invites using "send as" not "on behalf of" ... Using Outlook 4
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
M Outlook 2013 EAS, 3 imap accounts. Meeting invites not synced to outlook.com Using Outlook.com accounts in Outlook 1
S Modify recurring outlook invites based on form entry Using Outlook 0
B cant accept iCal calendar invites in Outlook 2007 (SP3) Using Outlook 4
N Outlook 2007 - Permissions for Meeting invites? Using Outlook 1
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 2
@ Outlook Using Outlook 2
