Hyperlinks Will Not Display Web Page
Learn2010
I'm new. I haven't been able to find the answer yet to this problem. When I click on a hyperlink in Outlook 2010, it does one of two things.
1. If IE8 is open, the hyperlink opens.
2. If IE8 is not open, I get the message that this webpage will not display and the button to diagnose problems.
I have tried the Fix It tool, sfc/scannow, and reinstalling IE8.
Anybody know how to fix this?
Learn2010
I want to also add that when I click the hyperlink, the link does open. However, it has the cannot display message and the diagnose button. I can copy and paste the link into another window and it will open.
Learn2010
No. I have done all that. I even reloaded IE8. I have a different error. The browser opens with the correct URL. This message is on the screen:
"Internet Explorer cannot display the webpage"
Below that is the button with the text "Diagnose Connection Problems."
Again, let me go over the details.
1. If IE8 is open, the link opens.
2. If IE8 is not open, I get the error above.
Forum Admin
The solution on that page might fix your problem... unless it's the same thing I see occasionally, which i pass off as IE being goofy. It happens not just with urls i click in Outlook, but also when i right click on a link in IE and choose Open in New Tab (or in new window). The page doesn't load... i refresh the page and it loads fine. I'm never quite sure where the problem lies - with the network, the browser, or windows. It is more frequent some days and I can go weeks without it happening.
Learn2010
After searching the internet and getting input from you guys, I think the problem is just a bad install of Office Professional. This all started about a week ago when I was given a new computer. Before this post I had the installers technical personnel address the issue. They tried to fix it but couldn't. That is when I posted. I appreciate your time and input and at this tiem iw ill just let it rest. If I can't live with it, I will have them reinstall Office Pro.
GregS Hyperlinks inactive Using Outlook 4
C Hyperlinks not working in Outlook Using Outlook 2
U Using VBA to creat hyperlinks in an email Outlook VBA and Custom Forms 3
B Insert Hyperlinks for attachments in Userform Outlook VBA and Custom Forms 5
H Outlook Images showing as hyperlinks Using Outlook 3
Jaegel Email Hyperlinks from one source won't open Using Outlook 4
Diane Poremsky Open All Hyperlinks in a Email Message New Slipstick.com Articles 0
Sarge USMC how do I enable hyperlinks in Outlook 2013 Using Outlook 1
B Right click-drag no longer creates hyperlinks Using Outlook 2
RookieOne Hyperlinks are not working in Outlook 2013 Using Outlook 1
G Outlook mailmerge images and images hyperlinks Using Outlook 1
J Hyperlinks to batch files with parameters Using Outlook 3
L Create hyperlinks to bookmarks in Outlook 2003 otf file Using Outlook 1
O Hyperlinks from Outlook 2007 Using Outlook 1
O Macro for creating hyperlinks in Outlook 2007 Using Outlook 3
N Unable to Open Hyperlinks in Outlook 2010 Using Outlook 3
A Hyperlinks to excel files Outlook Wishlist 0
P outlook 2007 - custom buttoms with hyperlinks to oft files Outlook VBA and Custom Forms 1
Q Creating hyperlinks Outlook VBA and Custom Forms 4
C Hyperlinks is becoming non-clickable in RTFBody format Outlook VBA and Custom Forms 5
R Capture Sender's Display name and Address Outlook VBA and Custom Forms 3
C Why won't Title display in message list? Using Outlook 1
M Daily Task List Minimized Cannot Display Using Outlook 2
C Outlook Mobile app email order randomized and display names stripped Using Outlook 6
N Contact display as Using Outlook 2
J Reminders Display then Disappear Using Outlook 13
O How to display senders email address (column) Using Outlook 1
O How to display number of items per .pst file Using Outlook 7
O Display more months in 'Tasks' Using Outlook 3
O How to display folder icons? Using Outlook 2
Treebys Array out of bounds .display 2016 Outlook VBA and Custom Forms 3
copperberry How to display incomplete tasks due on or before 7 days from now Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox New Slipstick.com Articles 0
P How to make outlook display alert appear on top of other windows whenever a new email is received? Outlook VBA and Custom Forms 1
T Outlook 2016 Calendar multiday event display Using Outlook 4
Diane Poremsky Display the Created Date field of any Outlook item New Slipstick.com Articles 0
