Task Start and Due Dates
DigitalDawn
Outlook 2007
Hi, I'm new here, and although I've been using Outlook (no exchange) for a few years, I've never explored it's Calendar/Task or Contact features.
So I finally decided to use Outlook as a full-fledged PIM and I'm having some difficulty getting the tasks to work for me.
When I click to create a new task I see that a task can have a start date and a due date. The problem is that I only want to use the start date, and have no due date associated with the task.
Here's the problem:
When I select my start date and then go to the due date, and click on "none", the start date is also erased and says none. I've tried playing with flags, and categories, and can't seem to create a task with a start date, but no due date. The weird thing is that I have some older tasks that were synchronized with my old PIM to Outlook and they have start dates but no due dates in Outlook.
What am I doing wrong?
Sorry, you can't create a task with a Start date but not a due date. Not even using VBA.
I use the Due Date (it's the date I'm due to start the task) and leave it overdue until completed.
Outlook won't touch imported items until you edit them, so if the old PIM supported no due date, Outlook will keep that value.
DigitalDawn
Outlook 2007
I guess I could also just extend the due date out several months or a year so that the font doesn't change in the ToDo Bar when it becomes due.
Thanks Diane.
As long as you aren't doing it to set a reminder, you could use conditional formatting to highlight what is upcoming.
I deselected the default overdue rule and made a new Overdue filter that highlighted things due more than 3 months ago in red. Things due between now and 3 month from now are blue.
(not sure why I thought reminders should come into play - you can set any reminder you want, regardless of the start or due date.)
G Arggh, weakness of reminder for every Task recurrence Using Outlook 0
P Can't paste an image into a task Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
T Report For Task Recurrance Outlook VBA and Custom Forms 4
E Can't accept or decline task (no button appears) Using Outlook 2
B Task Filter Not Working When I add too many criteria Using Outlook 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
B How to show concatenated categories in list task view? Using Outlook 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
M Daily Task List Minimized Cannot Display Using Outlook 2
S Codes for "Mark Complete" the task Outlook VBA and Custom Forms 2
W Deleting Sent Task Email, Deletes the task from my list Using Outlook 1
K Task priority modification Using Outlook 4
F Search folder for tasks in all task folders Using Outlook 1
K outlook workflow: automated task generation Outlook VBA and Custom Forms 4
F How to assign a task to a public task folder? Using Outlook 1
copperberry How to view all tasks across task folders Using Outlook 3
P Task Categories Using Outlook 2
L Email to task without changin formatting Outlook VBA and Custom Forms 16
P Custom form reverts from task Outlook VBA and Custom Forms 1
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
S Default Font in body of Task Using Outlook 0
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
K Daily task list > show tasks on the exact due date and not on the "current date" Using Outlook 1
Diane Poremsky Create a Task when a Message is Flagged New Slipstick.com Articles 0
Diane Poremsky Assign one task to several people New Slipstick.com Articles 0
Diane Poremsky Automatically create a task when sending a message New Slipstick.com Articles 0
Z Item.Recipients for Task Assignment on Send Outlook VBA and Custom Forms 10
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
S Task Update coming as email and not updating task Using Outlook 3
L Clear Offline (Task) Items using VBA Outlook VBA and Custom Forms 0
Diane Poremsky Create a Task from an Email using a Rule New Slipstick.com Articles 0
Diane Poremsky Task Request Status Update Address Missing New Slipstick.com Articles 0
Diane Poremsky Create Task or Appointment and Insert Selected Text New Slipstick.com Articles 0
M Automatically create event in calendar when task is created Outlook VBA and Custom Forms 1
