Outlook 2007 not working>> Please help tried everything
darkie
Problem:
Start in safe mode, it opens but then hangs with "Not responding", then basically freezes everything out
I've tried:
  1. running scan pst on most of the files
  2. reinstalled like 2 times
  3. It works on the other user account. (prompts to enter email address)
I am running Windows 7. I dont want to reinstall windows.
I live on my outlook really need it to work.
help help help
So to fails in Safe mode too?
See if renaming the profile registry key fixes it.
Rename
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem
to
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem-old
Complete instructions and screenshots:
Error Opening Outlook and Control Panel's Mail Applet - Slipstick Systems
ricky321
It seems your pst file has reached to its maximum size limit or some anti virus application may stopping your MS Outlook to stop smoothly. Try to disable the AV and remove old messages to reduce the size of your pst file.
darkie
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
L Outlook 2007 - Macro Re Search Using Outlook 16
D Outlook (Office) 2007 & Windows 10 Pro Using Outlook 6
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
