Reminders keep coming to users' calendar
muvanni
We have one user (Outlook 2010) Exchange 2010, that keeps receiving a recurring (apparently) reminder at the same time on the same day. Her calendar (mailbox) is getting full but we can't seem to stop it. I have disonnected the mailbox, let the system maintenance run overnight, reconnected the mail box but the reminder is still coming in. How can I top this? Have been using Exchange for a decade and I have never had this happen. Help???!
Have you tried the cleanreminders switch?
Does the reminder belong to a meeting or an appointment? If so, deleting the original item should fix it too... if you can find it. If it's orphaned, you'll need to use cleanreminders.
Delete reminders that keep returning - Slipstick Systems
S Reminders keep popping up, even after dismissing them Using Outlook 9
L Why do Outlook reminders keep popping up when I sync my data? Using Outlook 5
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 0
P Reminders Window stops being displayed, even with /resetfolders or /cleanreminders Using Outlook 8
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
J Reminders Display then Disappear Using Outlook 13
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
T populate calendar with appointments and send reminders Using Outlook 1
D Outlook for Android - Dismiss Reminders? Using Outlook 0
M flagged contacts suddenly disappeared from Reminders Using Outlook 3
A Birthday reminders now ending after 10 years?? Using Outlook 4
M Reminders or Notifications for Internet Calendars Using Outlook 1
E Meeting reminders are set for the recipient Exchange Server Administration 9
P Outlook 2013 reminders firing late, in batches Using Outlook 0
Diane Poremsky How to choose which Calendar creates reminders? New Slipstick.com Articles 0
E Are reminders local or global? Using Outlook 2
D Reminders in Outlook shared calendar Using Outlook 2
Z Reminders for all members of a shared calendar Using Outlook 1
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
PSittner Email Reminders From Excel File Outlook VBA and Custom Forms 6
J Duplicate Reminders Using Outlook 5
D Add tasks to reminders and calender? Using Outlook 1
P open reminders missing after copying outlook pst file Using Outlook 2
A Calendar Reminders are Removed with Sync to Outlook.com Using Outlook.com accounts in Outlook 11
W Midnight bug - Outlook Today & reminders Using Outlook 5
H Calendar entry reminders in Outlook.com Using Outlook.com accounts in Outlook 11
C outlook 2013 task reminders vs. outlook.com task reminders Using Outlook.com accounts in Outlook 8
M suddenly cannot set outlook 2007 contact reminders Using Outlook 2
D OL 13 Reminders Using Outlook 4
J Reminders dismissed on one computer re-appear on Outlook on second computer Using Outlook 1
S No Pop Up Reminders in Outlook 2013 Using Outlook 1
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 0
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 2
C shared calendar reminders Using Outlook 6
R How to avoid reminders from delegators' Calendars? Using Outlook 1
A How To Setting Multiple Reminders Using Outlook 1
S Reminders aren't showing up Using Outlook 3
G After syncing with iCould appoinmnet reminders do not show in the to-do bar Using Outlook 9
S Calender reminders question Using Outlook 13
D outlook reminders dont come to front :/ Using Outlook 4
M Outlook 2007 Calendar Reminders Using Outlook 1
B [outlook-users] Re: Why have I gotten to many "reminders" for birthdays that "occurred" on Jan. 1??? Using Outlook 3
D Reminders Problema after Profile Account Windows 7 Using Outlook 13
D Pop up Reminders are not working Using Outlook 2
