rule to change subject, pull email addresses from body, and forward with templ
moe0303
Outlook 2007
template.
I want to create a rule which will be applied to emails with specifc text in the subject field. I want to "reply" to the email, but I want the reply to go to an email address contained within the message body (not the original sender). I also want to change the subject to "Heat Ticket" and a number pulled from the message body. Once all that is sorted, the rule would send a template to the new email address.
I see the option in the rules to run a script. Can I use that to complete this action? If so, how? I'm not a programer and have very limited code experience.
Thanks in advance for any help you can give.
-Moe
Re: rule to change subject, pull email addresses from body, and forward with t
Yes, you would use Run a Script. I have sample scripts available.
Is the address (and number) you want to use easily identifiable in the message? Ie, you can search for a specific word or phrase and the address always follows.
Links to my samples are at Outlook's Rules and Alerts: Run a Script - Slipstick Systems
You'll also need to get the address and number - Use RegEx to extract text from an Outlook email message - Slipstick Systems
moe0303
Outlook 2007
Thanks so much for your reply, Diane.
I'm not sure I understand how to implement (or modify) your code for my purposes. The number will always follow the word "Ticket". I would like to pull any email address within the message body. The only thing that I can guarantee will be the same each time is the domain of the email. Using the information from article about extracting text, I came up with the following:
> pattern="(Ticket\s*(\d*)\s*)"
' Starts with "Ticket" + some white space + some digits + white space
> pattern="((\w*)@hotmail.com\s*)"
'starts with some alphanumeric string +"@hotmail.com" + some white space.
Are those correct?
Once I have extracted the text, how do I get the information to do what I want?
Sample message:
Ticket 123456789 has been assigned.
please contact moe0303@hotmail.com with any questions.
I would want the rule to send a pre-prepared message with the subject "Work Ticket 12345678" to moe0303@hotmail.com.
I know I would have to create a template and I think I can do that, but I don't know how to write the code.
Can this be done?
Thanks again for all your help.
-Moe
moe0303
Outlook 2007
Dear moderators,
I apologize for trying to reply to this thread 1000 times. I didn't see the pop-up till just now which says it will have to be approved by a moderator, and I feel like a fool. Please forgive me.
-Moe
Not a problem - I'm not sure what flagged it for moderation...
This code should get you halfway there (assuming I didn't make any stupid mistakes in it, i didn't test it) - i need to check on how to get the address since it's a second pattern rather than part of the number pattern.
Sub ChangeSubjectForward(Item As Outlook.MailItem)
   Dim oItem As Outlook.MailItem
   Dim Reg1 As RegExp
   Dim Reg2 As RegExp
   Dim M1 As MatchCollection
   Dim M As Match
   Dim EntryID As New Collection
   Dim strID As String
   Set Reg1 = New RegExp
   Set Reg2 = New RegExp
   strID = Item.EntryID
   Set oItem = Application.Session.GetItemFromID(strID)
   With Reg1
       .Pattern = "(Ticket\s*(\d*)\s*)"
       .Global = True
   If Reg1.test(oItem.Body) Then
       Set M1 = Reg1.Execute(oItem.Body)
       For Each M In M1
         strCode = M.SubMatches(1)
   With Reg2
       .Pattern = "((\w*)@hotmail.com\s*)"
       .Global = True
   If Reg2.test(Item.Body) Then
       Set M1 = Reg2.Execute(Item.Body)
       For Each M In M1
         strAlias = M.SubMatches(1)
'Item.Subject = "Heat Ticket " & strCode
'Item.Save
Set myForward = Item.Forward
myForward.Recipients.Add strAlias & "@hotmail.com"
myForward.Subject = "Heat Ticket " & strCode
myForward.Display 'Send
Set oItem = Nothing
- - - Updated - - -
BTW, for testing, i have it set to display the message rather than send it.
I updated the code above - it worked in a simple test here. I changed it so the subject is changed only in the forward and FW is removed. If you want the FW, use the original line which i commented out.
moe0303
Outlook 2007
I'm getting a "user defined type not defined" error on the following line: Dim Reg1 As RegExp
Is RegExp something I have to install?
moe0303
Outlook 2007
Awesome! Sorry I missed that part.
I actually like having it display the message for now.
Now, how do I get it to pre populate a message? I have a template named "Review" if that helps.
Thanks again for your help.
-Moe
you'll need a slightly different code for below the '---- line in the macro - from Run a Script Rule: Send a new message when a message arrives - Slipstick Systems
instead if
Set oItem = Nothing
use
Dim objMsg As MailItem
Set objMsg = Application.CreateItemFromTemplate("C:\path\to\review.oft")
objMsg.Recipients.Add strAlias & "@hotmail.com"
objMsg.Subject = "Heat Ticket " & strCode
objMsg.display '.Send
Set objMsg= Nothing
moe0303
Outlook 2007
Thank you so much.
It's working great except for one little quirk. If the email address uses a ".", it wont catch the whole first part. For example, some people use their first.mi.last@hotmail.com. and it only catches last@hotmail.com.
I tried switching the \w* to \W*, but that didn't work either.
Any advice?
Try
.Pattern = "(([a-z0-9.]*)@hotmail.com\s*)"
That works as i just tested it. (.*) works too, but it gets the entire line - Outlook resolves what it sees as the address but but the display name looks awful
snoopyb98
What I'm wanting the script to do is this: extract the email address from an email, which is listed after "Email Address:" in the email, create a new message in which the recipient is that extracted email address with a new subject and the body of the email to be from an oft, then sent.
So, I need a little help. I have formulated a script with the information here, part of it worked one time, I made an adjustment, then the script doesn't seem to work at all, or do anything, but there are no errors that it brings up. This is what I have:
PHP:
Sub First(Item As Outlook.MailItem)
   Dim Reg1 As RegExp
   Dim Reg2 As RegExp
   Dim M As Match
   Dim strID As String
  With Reg1
       .Pattern = "(Email Address:\s*(\d*)\s*)"
       .Global = True
       For Each M In M1
   With Reg2
       .Pattern = "([a-z0-9.]*)@([a-z0-9.]*)"
       .Global = True
       For Each M In M1
 'Item.Subject = "New Subject Title" & strCode
'Item.Save
Set oItem = Nothing
Set objMsg = Application.CreateItemFromTemplate("C:\Documents and Settings\Name\My Documents\First Email.oft")
objMsg.Recipients.Add strAlias & "[a-z0-9.]*)@([a-z0-9.]*)"
objMsg.Subject = "New Subject Title" & strCode
objMsg.Display '.Send
Set objMsg = Nothing
Any and all help would be greatly appreciated. I've dabbled in writing scripts before, but I'm by no means proficient in them. They are great when they work!
V rule to Find some words in the subject, change subject then forward Using Outlook 1
B Change identity or "from" field if a rule matches Outlook VBA and Custom Forms 14
N Autoresponder won't send to 'noreply@...' and need to change rule to send to on behalf person. Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
Ascar_CT Rule behavior analysis - any tools available? Using Outlook 0
Liza Creating a rule in outlook to filter messages Using Outlook 0
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
B custome rule Outlook VBA and Custom Forms 2
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
Diane Poremsky Create a Task from an Email using a Rule New Slipstick.com Articles 0
M Rule option Using Outlook 2
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Transactional emails - mail rule Using Outlook 3
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
