Trouble importing data to radio buttons Business Contact Manager 2010 (BCM)
alexbreeze
I'm trying to import contacts from Excel into BCM 2010 - including to custom fields I've created that are yes/no radio buttons.
Could someone please tell me if it's possible to import this data and automatically activate the radio button if the field in Excel is 'yes'?
Similar question applies to automatically importing and activating the 'Primary contact' field.
I've tried various ways without success. If I view the data as a list and add the relevant columns, I can see the 'No' fields - but no 'yes' fields import.
Hope that makes sense.
Thanks for your help!
Re: Trouble importing data to radio buttons Business Contact Manager 2010 (BCM
i don't have BCM installed to check (waiting for BCM 2013) but you can only import what you can map, and that usually doesn't include custom fields. Not sure if ContactGenie - Microsoft Outlook Contact Import/Export tools might work.
Durdane
I had the same problem and looked over the internet. Beside the fact I couln't find any info on fieldtypes in BCM, I could not find information on this topic as well.
I started to improvise with importing small excel files into BCM, and after many hours I found the solution.
Just use the booleans "TRUE" or "FALSE" (without the colons) in a text field in excel. So don't mess around with functions or whatever... It will convert in a checked or not checked box!
Happy me! ;-)
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
G Trouble with Office 365/2016 Using Outlook 3
M Trouble downloading Outlook on an Android phone Using Outlook 4
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
U Trouble migrating Contacts (2002) to People (2013) Using Outlook 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
B Trouble Adding @Outlook.com Email Accounts Using Outlook 3
K Trouble converting the ANSI PST to a Unicode PST Using Outlook 4
U Trouble for sharing Calendar Using Outlook 3
S Trouble setting up Outlook Connector to sync with windows live Using Outlook.com accounts in Outlook 3
T Trouble with creating database BCM (Business Contact Manager) 1
K Trouble using SaveAs Outlook VBA and Custom Forms 3
M trouble connection to remote database BCM (Business Contact Manager) 1
O Importing Mbox - anyone out there having experience with this tool... Using Outlook 2
B Importing business card into Outlook for SIgnature Using Outlook 1
S Importing Ribbons Not Saved Using Outlook 7
Diane Poremsky Importing Lists from Excel to Outlook New Slipstick.com Articles 0
B Importing Text from Excel to Outlook 2013 Calender Using Outlook 0
Christopher M Importing from Eudora Update Using Outlook 5
Christopher M Importing from Eudora Using Outlook 7
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
S Importing emails to contacts Using Outlook 3
Z Importing PST files from Outlook 07 to Outlook mac Preview Using Outlook 1
Z how to make OL (2007) to use custom contact form when importing / opening .VCF? Using Outlook 1
P Importing Thunderbird email to outlook Using Outlook 2
K Importing appointment body from excel in outlook 2010 Using Outlook 1
A Importing too many emails from Gmail Using Outlook 2
J Importing to the correct calendar from Excel 2010 to Outlook 2010 Outlook VBA and Custom Forms 2
S Possible to link to ics file without importing? Using Outlook 4
L Importing Opportunities in to BCM 2013 BCM (Business Contact Manager) 0
LarryH Importing csv file to custom form/fields? Using Outlook 3
T Importing Excel 2010 data into Outlook Calendar 2010 Using Outlook 12
W Importing .pst from Outlook 2010 (Win7) to Outlook 2013 (Win8.1) Using Outlook 2
V Importing Rules in Outlook 2013 Using Outlook 2
D Importing custom fields into custom form in BCM BCM (Business Contact Manager) 1
V Problem not having Contacts folder after importing emails from Yahoo. Using Outlook 0
