outlook printing assistant Help editing template
adavison2
Hi i am a school ICT technician i have edit one of the XML templates and almost got what i want just one problem remains i want to edit code below underlined and bold. height i want to change to either auto or maxheight minheight so the i can wrap text if needed but it seem to only accept height and crashes if I set height to auto the reason text so big is we put up on board for teachers to see any segustions
<alldayappointment
<alldayappointment <strong=""><alldayappointment <strong=""
SingleAllDayArea Orientation="Top" MinSize="5" MaxSize="500" Padding="1" BorderThickness="0,0,0,0" BorderBrush="style!SingleLineStroke"> <AllDayAppointment Height="58" Margin="5,0,5,1" Style="SingleAppointment"
<Bar Visibility="Collapsed" Orientation="Left" Width="5" BorderThickness="0,0,1,0"
<ConditionalFormat Condition="BusyStatus eq 'Free'" Visibility="Visible" Style="SingleAppointmentBarFree" /
<ConditionalFormat Condition="BusyStatus eq 'Tentative'" Visibility="Visible" Style="SingleAppointmentBarTentative" /
<ConditionalFormat Condition="BusyStatus eq 'OutOfOffice'" Visibility="Visible" Style="SingleAppointmentBarOOF" /
</Bar
<Content Orientation="Fill" Margin="2,0,2,0" HorizontalAlignment="Center" Separator="116" SeparatorFontFamily="WingDings" FontSize="36pt" TextWrapping="Wrap"
<ContentElement Source="Subject" FontWeight="Bold" /
<ContentElement Source="Location" /
<ContentElement Source="Organizer" /
<ContentElement Source="CategorySymbols" /
</Content
</AllDayAppointment
</SingleAllDayArea>
<content orientation="Fill" margin="2,0,2,0" horizontalalignment="Center" separator="116" separatorfontfamily="WingDings" fontsize="36pt" textwrapping="Wrap"> <contentelement source="Subject" fontweight="Bold"
<contentelement source="Location"
<contentelement source="Organizer"
<contentelement source="CategorySymbols"
</contentelement></contentelement></contentelement></contentelement></content
</alldayappointment></alldayappointment></alldayappointment>
adavison2
not sure how to paste code it get del parts
you either need to remove or change the < brackets or paste it into notepad and upload the file. The board software doesn't handle some coding. :(
AFAIK, you can't use an auto font size or appointment size. Appt height controls the height of each appt and the minsize/maxsize settings controls how many appointments can be displayed.
What happens if you don't set a height?
Have you seen CPAO: Editing a Daily Template - Part 1 - rtopken - Site Home - TechNet Blogs These articles were written by someone on the CPOA team.
adavison2
uploaded two .zip if you want to have a look it to do with the all day appointments need to be big font just want the thing to auto size just rename do .calx you will see what i mean one alldayappointiment height is set to 58 the other 120 in the 120 one it will wrap text if more than 37 char long
i did try to remove the height att but it says it is required but cant see where this requirement is set
thanks
  • school cal.zip
  • school cal3.zip
A Emailing Calendars Created in Outlook Calendar Printing Assistant Using Outlook 3
Y Outlook 2010 or Calendar Printing Assistant Using Outlook 2
T Printing from Outlook is now defaulting to "Shrink to Fit"! Using Outlook 5
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
G booklet printing in outlook 2007 Using Outlook 1
M Outlook 2013 is printing headers only Using Outlook 4
D Printing Attachments Automatically in Outlook 2010 Using Outlook 1
J outlook printing Using Outlook 2
J Printing Calendar in Outlook 2013 Using Outlook 0
C Printing Outlook Form Controls via Word Using Outlook 11
K Printing & Saving Outlook Contacts Using Outlook 3
P Printing Issues in Outlook 2007 Using Outlook 1
E Outlook 2010 network printing problems Using Outlook 4
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
S How to remove tracking from printing - outlook 2010 Using Outlook 4
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Using Outlook 2
M Outlook 2010 task line printing Using Outlook 1
W Calendar Printing with Outlook 2010 (64 bit) Using Outlook 1
J Outlook 2003 - Tasks - Printing Notes Using Outlook 1
R Header not printing in Outlook 2010 Using Outlook 3
P Printing problems with MS Outlook 2000 Using Outlook 1
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
