Outlook 2010 using Quick Print to print attachments
jeanie23
In Outlook 2003, a user could right click on email attachments and choose quick print to print. After choosing that option the attachment that had been sent to the printer would stay highlighted so the user could see where she left off and which ones she still needed to print. This is not the case in Outlook 2010. Anyone know of a way to mark the attachments that have been printed? This user gets emails with LOTS of attachments and, by necessity, cannot print all attachments at the same time. Thanks.
larry
I noticed that too (with Save as), and the only way i know to keep the attachment highlighted is to select it so it previews. I guess the reason it jumps back to message is because of the attachment preview feature.
You can also turn off attachment preview in tools, options, trust center, attachment options, but if you do, you lose Quick print and have just a print option. Plus, you'll also lose attachment preview.
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
B 0x800CCC0F Error using POP3 in Outlook 2010 and 2013 Using Outlook 1
UncleBill Unable to delete items from gmail IMAP Trash using Outlook 2010 Outlook VBA and Custom Forms 5
B Outlook 2010: using /altvba switch Using Outlook 1
S Using both My Calendar and iCloud Calendar in Outlook 2010 Using Outlook 4
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
G Using Outlook 2010 on POP3 to Outlook.com auto deletion on Web Using Outlook 3
T Using Outlook 2010 in Outlook2003 as backup ? Using Outlook 21
N Sending encrypted signed mail using outlook 2010 Using Outlook 1
P Multiple accounts and single Calendar file (Outlook 2010, using Connector) Using Outlook 1
C Deleted email message using Outlook 2010 Using Outlook 2
S Using Multiple Signatures in Outlook 2010 Using Outlook 9
J Problem using drag and drop to attach an html email in Outlook 2010 Using Outlook 18
