Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive
dfolmar
Recently, we have had issues with the automatic send/receive within Outlook 2010. Emails are getting stuck in the outbox, they are not always being received automatically and sometimes not at all unless we reboot our computer. I have already changed the automatic send/receive to 1 minute and made sure that the "Disable scheduled send/receive" button is NOT checked. We have tried moving emails from the Outbox to drafts and resent them from there. This sometimes works, sometimes not but it can be very time consuming with the volume of emails that we send. We have also resent the emails from the other email address that we have set up in Outlook which, again, sometimes works, sometimes not and is very time consuming. I would appreciate any advice/fixes that anyone may offer. Thank you for your time!
Re: Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/recei
1. Set the autosend and receive to at least 5 -8 minutes. Higher if you send and receive a lot of mail. You want to be sure one mail pass is finished before the next one starts. Set outlook to send immediately - if you want to hold the mail for a little bit, you can use an after sending rule to delay sending for up to 120 minutes.
Does mail send if you don't look in the outbox? If so, this is caused by an addin - iCloud, onenote addin, and anyivirus scanners are the usual culprits, but there are others. See Messages are stuck in the Outbox - Slipstick Systems for other causes.
CP3044
Outlook 2007
I too am having problems in that outgoing emails are getting stuck in my outbox. I am using Outlook 2007 on my laptop and am getting a message which states"Outlook cannot connect to the outgoing SMTP email server. Contact Server Administrator or ISP"
The error code is 0x80042109 and I have contacted TalkTalk (my ISP), who have stated that my.
smtp is TalkTalk and that the port is 587.
Entering this info has made no difference to the problem, even after disabling AVG's ability to scan all emails.
My laptop is using Windows 8.
I have also checked progress of emails when asking them to send, which sometimes states that they have been sent!
I have also tried dragging the emails into the Draft section, opening them and sending, all to no avail. Can anyone resolve???
Does it work if you use Safe mode?
On the More Settings, Outgoing server tab, are you authenticating with the server? When you set port 587, did you also set it to use SSL?
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
James Emails Stuck In Outlook Outbox Happening Alot Using Outlook 1
B Cannot send emails-stuck in OutBox: OUTLOOK 2013 Using Outlook 4
J Emails stuck in Outlook outbox Using Outlook 11
X Exchange 2013 - Emails stuck in Outbox folder Exchange Server Administration 3
A Emails stuck in Outbox/new messages can't be found. Using Outlook 2
J "Reply" emails do not send and get stuck in outbox Using Outlook 4
F emails stuck in outbox Using Outlook 1
P Outlook 2007 offline created emails stuck in Outbox Using Outlook 3
E Outlook 2010 calendar emails stuck in outbox Using Outlook 3
T emails stuck in outbox Using Outlook 3
J Emails getting stuck in Outbox Outlook VBA and Custom Forms 3
T Outgoing emails stuck in Outbox Using Outlook 11
K Emails stuck in 'Junk' folder Using Outlook 0
C Multiple emails Using Outlook 3
Phillip Bit.ly emails Using Outlook 1
G Alerting on missed emails in conversation Outlook VBA and Custom Forms 1
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
M Group of emails Using Outlook 1
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
P Flagging emails in conversations Using Outlook 2
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
F not receiving emails until i re-login Using Outlook 2
A Record opened emails for reopening later Outlook VBA and Custom Forms 16
R Deleting emails from storage folder Outlook VBA and Custom Forms 1
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
