Need help with combo boxes in messages!
mixdkid
Outlook 2007
I need help trying to implement a template for my emails to send to groups at my company. I want to do something like this
just focusing on the white part of that Screen Shot. Can I put those kind of combo-boxes into my email message body so that I could just select the appropriate categories and have it sent to my list of contacts?
Body
Date and Time: System Generated.(The computer's time should be time-stamped in this email.)
Event Type: {Outage, Degradation,Information,...}
Event Status: {Investigation,Outage,Information}
An example of how I'm trying to set this up
Subject: (Status of the problem I'm sending)
Date and Time: 02/01/2013
Event Type: Outage
Event Status: Investigation
Please if anyone could help me out I would be so grateful. I'm new to programming and have been looking around for weeks and nothing that could point me in the direction that I should be going for this. It would make my reports much easier if I could get this going. Its such a tedious thing for filling this out every day :(
You can do it in Outlook using a combination of a macro and userform.
Date: added by VBA
Event type, location, event status would be in a userform that pops up.
Subject: added by vba
I'm in the middle of something right now (taking a break to clear my head) - take a look at Select from a list of subjects before sending a message - Slipstick Systems - it will point you in the right direction. Add a button to the QAT to run the macro.
You'll need something like this in the userform
Private Sub UserForm_Initialize()
 With ComboBox1
   .AddItem "Event type1"
   .AddItem "Event type2"
 With ComboBox2
   .AddItem "Status1"
   .AddItem "Status2"
 With ComboBox3
   .AddItem "location1"
Private Sub CommandButton1_Click()
   lstEvent = ComboBox1.ListIndex
  lstStatus = ComboBox2.ListIndex
  lstLoc = ComboBox3.ListIndex
   Unload Me
and this is the macro - i don't think i missed anything.
Public lstEvent As Long
Public lstStatus As Long
Public lstLoc As Long
Public Sub StatusMessage()
Dim oMail As Outlook.MailItem
UserForm1.Show
   Select Case lstEvent
   Case -1
        txtEvent = "some event"
   Case 0
         txtEvent = "different event"
   Case 1
        txtEvent = "bad event"
Select Case lstStatus
   Case -1
        txtstatus = "some status"
   Case 0
         txtstatus = "different status"
   Case 1
        txtstatus = "bad status"
Select Case lstLoc
   Case -1
        txtloc = "here"
   Case 0
         txtloc = "there"
   Case 1
        txtloc = "everywhere"
Set oMail = Application.CreateItem(olMailItem)
oMail.body= Now() & vbcrlf  & txtEvent  & vbcrlf & txtstatus  & vbcrlf & txtloc
oMail.subject =  txtstatus
oMail.Display
mixdkid
Outlook 2007
Thank you so much for the reply Diane!!!!!!
I will try this out on Monday at work. But I'm highly positive this will work out for me by looking at your other work. Thanks again :)
mixdkid
Outlook 2007
Thanks again Diane!
This worked perfectly! I have another question to ask you or anyone else that could lend a helping hand :), I decided to put in a text box for the user to input for the generated email. But when i try and declare a string for the text box and stick it into my body it doesn't show up:
This is the forum with the Text boxes that I tried to add in bold
 With ComboBox2
   .AddItem "Outage"
   .AddItem "Degradation"
   .AddItem "Information"
   .AddItem "Investigation"
   .AddItem "Degredation and Restoration"
   .AddItem "Outage and Restoration"
   .AddItem "Change Window Open"
   .AddItem "Change Window Closed"
   .AddItem "Maintenance Window Open"
   .AddItem "Maintenance Window Closed"
 With ComboBox3
   .AddItem "Germantown"
   .AddItem "North Las Vegas"
   .AddItem "Detroit"
   .AddItem "{Name} Gateway"
 With ComboBox4
   .AddItem "Investigation - Initial"
   .AddItem "Investigation - Update"
   .AddItem "Investigation - Closed"
   .AddItem "Outage - Initial"
   .AddItem "Outage - Update"
   .AddItem "Outage - Resolved"
 With ComboBox5
   .AddItem "Jupiter Management System"
   .AddItem "Spaceway Management System"
   .AddItem "Ordering"
   .AddItem "Billing"
   .AddItem "Satellite Transport"
   .AddItem "Terrestrial Transport"
   .AddItem "Voice Services"
   .AddItem "Disaster Recovery Services"
   .AddItem "High Availability Network"
   .AddItem "Customer Care Portal"
   .AddItem "GTECH NOC 3"
   .AddItem "ROW44 Europe Transport"
   .AddItem "XCI Transport"
   .AddItem "XCI Management"
   .AddItem "Commissioning"
   .AddItem "Activation"
   .AddItem "Jupiter Transport Services"
 With ComboBox6
   .AddItem "Consumers"
   .AddItem "Enterprise"
   .AddItem "Enteprise and Consumers"
  lstEvent = ComboBox2.ListIndex
  lstStatus = ComboBox4.ListIndex
  lstSer = ComboBox5.ListIndex
  lstCostumer = ComboBox6.ListIndex
[B]Dim strTic, strDes As String
  strTic = TextBox1.Text
  strDes = TextBox2.Text[/B]
   Unload Me
mixdkid
Outlook 2007
And this is the Macro part that you created for me with the added text boxes I've tried to add and nothing shows up for the Ticket number or the Description field when I enter it in.
Public lstNo As Long
Notification.Show
Case -1
txtEvent = "Outage"
Case 0
txtEvent = "Degradation"
Case 1
txtEvent = "Information"
Case 2
txtEvent = "Investigation"
Case 3
txtEvent = "Degredation and Restoration"
Case 4
txtEvent = "Outage and Restoration"
Case 5
txtEvent = "Change Window Open"
Case 6
txtEvent = "Change Window Closed"
Case 7
txtEvent = "Maintenance Window Open"
Case 8
txtEvent = "Maintenance Window Closed"
Select Case lstLoc
Case -1
txtLoc = "Germantown"
Case 0
txtLoc = "North Las Vegas"
Case 1
txtLoc = "Detroit"
Case 2
txtLoc = "{Name} Gateway"
Case -1
txtStatus = "Investigation (Initial)"
Case 0
txtStatus = "Investigation (Update)"
Case 1
txtStatus = "Investigation (Closed)"
Case 2
txtStatus = "Outage (Initial)"
Case 3
txtStatus = "Outage (Update)"
Case 4
txtStatus = "Outage (Resolved)"
Select Case lstSer
Case -1
txtSer = "Jupiter Management System"
Case 0
txtSer = "Spaceway Management System"
Case 1
txtSer = "Ordering"
Case 2
txtSer = "Billing"
Case 3
txtSer = "Satellite Transport"
Case 4
txtSer = "Terrestrial Transport"
Case 5
txtSer = "Voice Services"
Case 6
txtSer = "Disaster Recovery Services"
Case 7
txtSer = "High Availability Network"
Case 8
txtSer = "Customer Care Portal"
Case 9
txtSer = "GTECH NOC 3"
Case 10
txtSer = "ROW44 Europe Transport"
Case 11
txtSer = "XCI Transport"
Case 12
txtSer = "XCI Management"
Case 13
txtSer = "Commissioning"
Case 14
txtSer = "Activation"
Case 15
txtSer = "Jupiter Transport Services"
Select Case lstCustomer
Case -1
txtCustomer = "Consumers"
Case 0
txtCustomer = "Enterprise"
Case 1
txtCustomer = "Enterprise and Consumers"
oMail.Body = [B]strTic & strDes &[/B] "Date and Time:" & vbTab & vbTab & vbTab & Now() & vbCrLf & "Event Type:" & vbTab & vbTab & vbTab & txtEvent & vbCrLf & "Location:" & vbTab & vbTab & vbTab & txtLoc & vbCrLf & "Event Status:" & vbTab & vbTab & vbTab & txtStatus & vbCrLf & "Description:" & vbTab & vbTab & vbTab & "*Insert description*" & vbCrLf & "Customers affected:" & vbTab & txtCustomer & vbCrLf & "Service Affected:" & vbTab & vbTab & txtSer & vbCrLf & "ETR:" & vbTab & vbTab & vbTab & vbTab & vbTab & "*Fill in date/time or uknown*" & vbCrLf & "Ticket number:" & vbTab & vbTab & vbTab & "*Fill in ticket number*" & vbCrLf
oMail.Subject = txtStatus & " - " & txtSer
oMail.Display
Set objApp = Application
Case "Explorer"
Case "Inspector"
Set objApp = Nothing
End Function
Hopefully I missed something minor and nothing big. Thanks in advance!!!!!!
Couple of problems:
1) You need to declare the strings publicly so the values are passed from the userform to the macro.
Public lstNo, lstEvent, lstLoc, lstStatus, lstSer, lstCostumer As Long
Public strTic, strDes As String
That should fix your problem.
If you are not selecting a contact (or another outlook item) to pull data from it, you don't need the function at the end.
This was my sample mail - i entered my selection into the first text box - you need another vbcrlf or two (or spaces) in the body string... and the cases need updated. The -1 case is what to use as a default if no selection is made.
Information, Detroit, Investigation - Update, Voice Services, EnterpriseTesting text box 2Date and Time: 2/8/2013 12:53:26 PM
Event Type: Investigation
Event Status: Investigation (Closed)
Description: *Insert description*
Customers affected: Enterprise
Service Affected: Disaster Recovery Services
ETR: *Fill in date/time or uknown*
Ticket number: *Fill in ticket number*
You can either use the same value for -1 and 0 or it like this:
Case -1
txtCustomer = "no value selected"
Case 0
Case 1
Case 2
with the cases fixed, i got this - i forgot to add spaces in the body code but made sure i added them at the end of the line in the text box.
Outage and Restoration, North Las Vegas, Investigation - Closed, GTECH NOC 3, Enterprise seeing if this works Date and Time: 2/8/2013 1:00:55 PM
Event Type: Outage and Restoration
Customers affected: Consumers
Service Affected: GTECH NOC 3
mixdkid
Outlook 2007
Wow your awesome!!
Question, where did you stick "Public lstNo, lstEvent, lstLoc, lstStatus, lstSer, lstCostumer As Long
Public strTic, strDes As String" at? I keep getting an error when I place this at the top of the page of the Macro page.
It goes at the top of the macro - those two lines replace this line:
What error message do you get? It needs to be at the top of the module.
mixdkid
Outlook 2007
I just redid it and copied and pasted what i posted in here, so everything is the same just replaced the top line in the macro page. Everything is working fine, but now i dont see the the "ticket number" or "description" data i enter.
Did you remove
from the userform code? (Sorry I forgot to mention that).
And to confirm, you have this line at the top too, after the one that sets all the indexes?
mixdkid
Outlook 2007
Excellent!!!!!!!! You are the best Diane!!!!!!!
You saved me from a pounding headache of confusion and made my boss happy. :D
Thanks!!
Alex Zuniga
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
X business owner in dire need of help outlook is not syncin my contacts! Using Outlook.com accounts in Outlook 2
D Need email verification for international emails, help? BCM (Business Contact Manager) 2
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
K Need help Publishing a new Task form! Outlook VBA and Custom Forms 1
A Need help in creating a mass emailing plugin Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 4
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
