Outlook 2007 QAT buttons not saving
rzj
Outlook 2007
I've defined some VBA code to run from QAT buttons in Outlook 2007 to switch between views (all messages and unread messages).
I can add the buttons to the QAT in the main outlook window and they work.
However when I exit Outlook and restart they are not saved. However the VBA routines are saved.
What am I doing wrong?
I wondered if I could add some code that ran on start up to re-add the buttons but I can't see any info about accessing the QAT from VBA code
Are you adding them to the QAT or creating toolbar buttons in the main interface?
The outcmd.dat file might be corrupt - find and delete it.
From Outlook 2007 is very slow - Slipstick Systems
WinXP: C:\Documents and Settings\<username>\Local Settings\Application Data\Microsoft\Outlook
Win7: C:\Users\<username>\AppData\Roaming\Microsoft\Outlook
Type or paste this shortcut in the address bar of Windows Explorer then press Enter to jump to the folder in either OS:
%USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook
rzj
Outlook 2007
I have 2 public subs.
I click the down arrow on end of QAT in main page, selecting add or remove buttons -> customise
Then select macro in the commands list
then drag macro name to QAT.
When I close and reopen its gone!
I've deleted outcmd.dat
After I did that it set macro security to block so I had to change it to no security, which allows me to run them but they still don't persist as buttons
Thanks for your help
Ray
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 1
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
L Outlook 2007 - Macro Re Search Using Outlook 16
D Outlook (Office) 2007 & Windows 10 Pro Using Outlook 6
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
P How to switch back from Outlook 2010 to Outlook 2007? Using Outlook 3
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
A Corrupt tasks in Outlook 2007 Using Outlook 1
