Custom field is read only
Palace
Hi There
I am looking to solve an issue where users want to be able to identify selected mesages they reuse as stationery items. A lot of the messages have the same subject so I created a cutom field in the folder and allowed in place editing but I get the message that the property is read-only. Same effect if I choose a yes/No type of field. How do you set the field to be writable?
Cheers
Peter
I finally got it to work with the yes/no and a text field- you need to enable in-cell editing but it wouldn't work until I turned off conversations (all are on the other settings dialog of customize view).
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
M Clear custom date field after recurrence Outlook VBA and Custom Forms 0
F copy data in Custom Field to other folder Outlook VBA and Custom Forms 2
T What code to use to move the custom field values to message body when sending e-mail ? Outlook VBA and Custom Forms 8
V Using custom field data in mail body + mailto hyperlink Outlook VBA and Custom Forms 7
L Quick step to fill custom field Outlook VBA and Custom Forms 1
Randy Redekopp Filtering a view based on a custom field Using Outlook 1
M moving custom field data between outlook and excel? Using Outlook 4
M Copy "To" Address Value from a Newly Created Email to the "To" Address Field of Custom Form Using Outlook 4
F Outlook 2010 - Need help with a custom field. Using Outlook 3
D Custom Form - Show field-filled doc a or b based on value of field x Outlook VBA and Custom Forms 4
J How to create a user defined dropdown list field for a custom contact form Using Outlook 3
S Custom field not populating in Custom View or Mail Merge Exchange Server Administration 2
S User defined field not showing in Custom view Exchange Server Administration 0
C Tasks > Field Chooser > Fields with dropdown menu (eg. Status). How to custom? Using Outlook 6
H How can you add a URL field in a Outlook Custom Contact form? Using Outlook 6
C Custom Form that allows a single SMTP header to be parsed to Field Chooser? Using Outlook 4
B Field Chooser missing custom form fields Using Outlook 0
R Need code to gather value of custom field on addressentry.details dialog box Using Outlook 3
G Displaying value of task subject field as values from two custom fields Using Outlook 4
K Can't use links in Outlook custom form text field Outlook VBA and Custom Forms 1
0 Add a date stamp to the note field of a custom form Outlook VBA and Custom Forms 1
J Making field editable in custom form Outlook VBA and Custom Forms 2
S Make field searchable in custom form in outlook 2007 Outlook VBA and Custom Forms 1
S Custom Yes/No column field Outlook VBA and Custom Forms 2
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
