How does outlook desktop work with outlook.com
Unclewilley
I have been searching for an explanation as to how Outlook desktop and outlook.com can interact. Is it possible to keep emails, contacts and calendar events in outlook.com AND download into outlook desktop? I would like to be able to use multiple PCs with outlook desktop all to the same accounts. When offline I need to be able to read/review email content, lookup contacts and calendar events. Also sync, as I do now, between iPhone and outlook desktop.
Is the above possible and if so, I would appreciate someone pointing me to setup instructions.
THANKS MUCH!!
It syncs the server (outlook.com) with Outlook - kinda like how Outlook syncs with Exchange server or iphone syncs over the air with Outlook.com.
You'll have a local copy of all of the messages, contacts, and appointments and changes will sync up to the server.
Unclewilley
I've downloaded the Hot Mail Connector and ran the install. The install process does not ask any config or other questions. It seems to finish the install; however, I can't find ANY reference to the installed program. Not listed in the Start Menu and I can not find it anywhere in the c:\programs directories. Any suggestions???
In Outlook, go to file, Account settings and Add a new account. Choose the manual option, select the Connector and then enter your email address and password.
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
A Does Outlook import Gmail Archive? Using Outlook 1
1Firefly Outlook 2013 Converstation preview does not show my last reply Exchange Server Administration 1
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
H Outlook.com calendar does not update from Outlook 2013 Home Premium Using Outlook 1
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
L Outlook 2007 does not start with Apple iCloud-Add-In activated Using Outlook 2
S Outlook 2013 To Do Task does not minimize. Using Outlook 0
D Outlook 2013 deletes emails, does not send them to Deleted Items or Trash Using Outlook 2
O Outlook 2010 does not open MS Word attachments Using Outlook 1
K Outlook 2007 Calendar - Time spinner does not function correctly Using Outlook 1
M Outlook Appointment item does not show the item outside the date range Using Outlook 2
H Reocurring outlook appointment (office 2010) does not update Outlook.com Using Outlook 3
F Outlook 2010 contact e-mail Display as: does not show contact name Using Outlook 2
P Reply All does not work in Outlook 2010 Cached mode Using Outlook 4
R Outlook 2013 does not show in default programs - how do I search Using Outlook 1
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 0
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 2
Fozzie Bear How does Outlook 2003 deals with IMAP configuration Using Outlook 8
J Does Outlook 2003 run on Windows 8 Professional? Using Outlook 2
E Does Outlook indexing work across multiple servers? Using Outlook 0
E Does Outlook 2010 support searching multiple .pst files simultaneously? Using Outlook 0
J Outlook 2003 does not send or receive imap mail from server Using Outlook 0
E Double clicking on from email address does no longer open corresponding contact in Outlook 2007 Using Outlook 7
S Compiler Error: Does not like Outlook.CommandBarControls.CommandBarControlPtr.Add Outlook VBA and Custom Forms 1
T Outlook's button 'Attach File' does not work Outlook VBA and Custom Forms 7
N why does vb not recognise outlook code? Outlook VBA and Custom Forms 1
D Why does BCM not always load when I restart Outlook? BCM (Business Contact Manager) 1
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
B Importing Contacts Does Not Use Defined Custom Form in Outlook 2007 Outlook VBA and Custom Forms 1
B RE: Why does Business Office Contact Manager shut down Outlook? BCM (Business Contact Manager) 3
D Where does Outlook store signatures? Outlook VBA and Custom Forms 9
