"Current View" settings across multiple users on same Exchange 2007 account.
eclipse75048
I have four people that are accessing the same department Exchange account using Outlook 2010 from different Windows 7 computers. Each user has their own personal Exchange account, as well as two other department accounts, in the same Outlook 2010 profile (i.e. the new way, not using the "Open these additional mailboxes" way.)
I would've assumed that a view would be a client only setting within Outlook, however if one of the users changes their "Current View" on their computer, it changes the view for the three OTHER users that also access that department Exchange account.
I had a number of other "quirky" issues with using multiple exchange accounts in one Outlook 2010 profile, but I've been able to find workarounds for all of those. This one is stumping me!
Any ideas?
Chris
Re: "Current View" settings across multiple users on same Exchange 2007 accoun
Unfortunately, views are not per outlook-client in mailboxes - everyone is an owner and can make changes from any computer.
If they opened them as additional mailboxes, not as owners, the views might be per-user - it's been so long since I've done that that I forget. :)
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
M Change default Current View on People Using Outlook 1
M Customize Current View of PST Files Using Outlook 2
S Count of Contacts In Current View BCM (Business Contact Manager) 1
C Calendar View Monthly Current Week at the Top Outlook Wishlist 2
C Calendar View Monthly Current Week at the top Outlook Wishlist 1
Q Remove filter from current view - outlook 2003 Outlook VBA and Custom Forms 4
S Macro to extract email addresses of recipients in current drafted email and put into clipboard Outlook VBA and Custom Forms 1
N Having Shared Calendar shift to Current day Using Outlook 0
E Conditional formatting - when current account <> received account ? Using Outlook 3
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
F "This action is not available in the current mode" Using Outlook 0
J Old unread emails on current date (MDaemon Server) Using Outlook 1
T Attach Current File to a new Email Using Outlook 0
K Daily task list > show tasks on the exact due date and not on the "current date" Using Outlook 1
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
R Inbox search, current folder, it's in there-but not found. Using Outlook 2
S Auto Create new Task upon Current Task completion Outlook VBA and Custom Forms 28
C Either there is no default mail client or the current mail client cannot ... Using Outlook 1
E Calendar Thumbnail current day background color Calendar Printing Assistant 3
G How can I identify in VBA if the current window is an item or a folder? Using Outlook 3
C Hover display of DL shows original owner, not current Using Outlook 2
T Outlook makes every appointment recurring and set to the current date/time Using Outlook 2
M Rules applied that aren't current Rules Using Outlook 2
D Save Current email in Directory. Outlook VBA and Custom Forms 1
L create new mail item from current item Outlook VBA and Custom Forms 4
K insert text into current position of pointer in mailcompose Outlook VBA and Custom Forms 1
S Either there is no default mail client or the current mail client cannot fulfill the message request Using Outlook 13
S VBA access current contact? BCM (Business Contact Manager) 1
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
X Re: how to access current text selection Outlook VBA and Custom Forms 1
T date/time field, current year Outlook VBA and Custom Forms 2
T current cursor position in the reply event Outlook VBA and Custom Forms 1
D Re: How to specify the "current entry id" to GetItemFromID? Outlook VBA and Custom Forms 1
T Re: mailItem.HTMLBody should retrieve only current text Outlook VBA and Custom Forms 1
