Outlook 2013 does not show in default programs - how do I search
Robin
Outlook 2013 32 bit
Just installed Outlook 2013. Alerts tell me there is no email associated with outlook and .ppt, etc. I cannot make Outlook 2013 my default because it is not listed - only Outlook 2010 is listed. I have to be able to send attachments. Outlook 2010 is still on the computer but you can understand hesitation in deleting 2010 until 2013 is working. Plus it never said 2010 had to go before 2013 was installed.
Secondly, I am unable to get the search feature of Outlook 2013 to work - searching for old emails is essential for me in my work. This is very frustrating.
HELP!!! please someone.......:eek:
Robin
What program are you trying to send mail from? Some programs will need to be updated to work with Outlook.
Which office suite did you install? If its a click to run version, it can be side by side with Outlook 2010, but you can only have one outlook open at once. Check in File, Office Account, About Outlook. It will say Click to Run or C2R somewhere in there.
1Firefly Outlook 2013 Converstation preview does not show my last reply Exchange Server Administration 1
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
H Outlook.com calendar does not update from Outlook 2013 Home Premium Using Outlook 1
S Outlook 2013 To Do Task does not minimize. Using Outlook 0
D Outlook 2013 deletes emails, does not send them to Deleted Items or Trash Using Outlook 2
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 9
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
