How to set a flag to follow up using VBA for outlook 2003
jyoshina
Thanks a lot for the How to set a flag to follow up using VBA page. it was very useful and works fine for my Outlook 2010. but i need the same method to be done for outlook 2003. when i tried this code i got run time error : 438 Run Time error 438 - Object doesn't support this property or method . i don't know how to fix this can you please help
it would be great if you could respond me back. thanks for your help in advance.
Outlook 2003 has colored flags so you need to tweak the code a little -
With objMsg
   .FlagIcon olPurpleFlagIcon
   .FlagDueBy = Now + 3
   .FlagRequest = "Call " & objMsg.SenderName
   .ReminderSet = True
   .ReminderTime = Now + 2
   .Save
jyoshina
Thanks!! is there any way to test whether i am getting remainder ? or should i wait for 3 days to test ?? this works fine and my mail got flagged in purple color
With objMsg
   .ReminderSet = True
   .Save
Right click on the flag and choose Add reminder. It should be set for Sat. at the same time as you ran the macro.
KoolPal
What can I do to make this prompt me for a custom message after "Call "??
I use inputbox before setting the flag -
strFollowup = InputBox("Enter the Followup text")
KoolPal
I can't see any option to edit my post hence double posting, sorry.
Alternate to my above request, is there any way I can prefill flagdueby & reminder setting and prompt for the entire Follow up flag box?
KoolPal
With objMsg
   .ReminderSet = True
   .Save
Can you please guide me how to use the strFollowup with the above code?
You should be able to edit posts for at least 30 minutes - that is going to be the new setting, if its set correctly. I'll have to check on it.
This should work - when the code hits the inputbox line, it will popup a dialog box asking you to enter the text.
dim strFollowup as String
With objMsg
    .FlagRequest = strFollowup & objMsg.SenderName
    .ReminderSet = True
     .Save
If you use the same set of followups, you could use a userform and select the names. An example of userforms is here http://www.slipstick.com/developer/select-list-subjects-sending-message/
KoolPal
With objMsg
    .ReminderSet = True
     .Save
Thank you very very much for this! This worked brilliantly as expected!
justicefriends How to set a flag to follow up using VBA - for addressee in TO field Outlook VBA and Custom Forms 1
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
F how do i set a reminder in onenote 2010 Using Outlook 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
O Set columns for all (sub)folders Using Outlook 8
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
F Set (flagged) reminder for next business day Using Outlook 4
L how to set downloaded cached emails Using Outlook 5
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge Using Outlook 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
M Exchange 2013 On premise set MessageRateLimit for User has no effect. Exchange Server Administration 0
A Block user to send emails to specific set of email ids Using Outlook 1
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
Diane Poremsky Exchange account set-up missing in Outlook 2016 Using Outlook 0
M To set the storage folder for an outgoing Outlook message Outlook VBA and Custom Forms 8
E Meeting reminders are set for the recipient Exchange Server Administration 9
M Help! Can't set up IMAP for gmail Using Outlook 2
P Last Change attribute set after viewing a public folder contact Exchange Server Administration 0
S Multiple Gmail account set up in Outlook 365 Using Outlook 1
Diane Poremsky Add attachments and set email fields during a mail merge to email Using Outlook 0
D Script to parse email and set a task Outlook VBA and Custom Forms 1
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
