Apply Category Color for Appointment Background Color
charith
I've been doing some modifications to WeekList01 template and I want to apply Category color as the background of Appointment. Is there anyway to apply ConditionalFormat for below column? I've attached my Content.xml file herewith.
View attachment Content.zip
Capture.PNG<column width="*" left="4" top="2" right="2" bottom="2"
<sources
</sources></column
I've attached the code snippet as an image as this editor doesn't like it.
Thank you,
Charith
charith
Thanks for your reply Diane. I have already tried the way that article explains and tried to add ConditionalFormat to this Content.xml file but failed. The reason is being that I don't have TimeSlot or Appointment tags in this Content.xml file. I have tried various ways to add Appointment and TimeSlot tags with ConditionalFormats but no success so far. Could you please point me how to add ConditionalFomat for this ?
<column width="*" left="4" top="2" right="2" bottom="2">
HTML:
           <List Orientation="Fill" FontSize="8pt" MinimumListWidth="60" ShowEmptyRow="true" MaxRowWrap="3"
			RowSize="16" TypeFilter="AppointmentsTasksAllDayAppointments" MinorLineCount="3" Style="SingleBodyBorder">
             <Columns>
               <column>
                 <sources>
                   <source name="Subject">
                   <source name="Due" startseparator=" (" endseparator=")" format="d">
                   <source name="Location" startseparator=" (" endseparator=")">
                   <source name="CategorySymbols" startseparator=" ">
                 </sources>
               </column>
R Apply a category to item in inbox view Outlook VBA and Custom Forms 1
E Apply customized Business Card for all users Outlook VBA and Custom Forms 0
Diane Poremsky Use Word Macro to Apply Formatting to Email New Slipstick.com Articles 0
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
Diane Poremsky Apply Outlook Stationery to Replies and Forwards New Slipstick.com Articles 0
B Apply two rules on one email Using Outlook 2
R Rules - apply to messages > n days old Using Outlook 2
B Unable to apply rule on Exchange server functional account Exchange Server Administration 1
M Apply different views to calendars Using Outlook 0
F Apply Follow up flag ONLY to the people cc'd. Using Outlook 1
T Is there a way to apply a macro before a signature is applied in email? Using Outlook 1
L Unable to apply SP1 to Exchange 2010 Exchange Server Administration 5
H Create/Apply auto formatting rules by VB? Outlook VBA and Custom Forms 2
bhamberg Contacts in a category Outlook VBA and Custom Forms 11
K Update Appointment category when changed in Excel Using Outlook 3
soadfan assign category (VBA) Using Outlook 7
J Automatic color category according to variable domains Outlook VBA and Custom Forms 4
Diane Poremsky Category Color doesn't Display in Inbox New Slipstick.com Articles 0
Wolfkc Unwanted Category "Starred in Android" Using Outlook 6
M receive mail when appointment category changes and create task from appointment Outlook VBA and Custom Forms 0
N VBA Outlook reference to Excel and assigning category Outlook VBA and Custom Forms 13
A recover contact category assignments Using Outlook 4
A Grouping emails using "From" causes a None Category Using Outlook 5
J Outlook Rules not show Master Category List Using Outlook.com accounts in Outlook 4
William getting custom form to load category colors Outlook VBA and Custom Forms 4
Diane Poremsky Categorize Messages using Contact Category New Slipstick.com Articles 0
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
T default category Outlook VBA and Custom Forms 2
L Change Category in a Task via macro Using Outlook 8
K Help! I selected every contact and mistakenly made them all the same category Using Outlook 1
R Filter Views by Category Using Outlook 2
S categories are being cut off after selecting from category pop up form Using Outlook 3
D Search on Category in Outlook 2013 Using Outlook 1
R Any idea why my category colours aren't showing in my calendar? Using Outlook 0
M Searching for categories not in the master category list Using Outlook 3
L Category List Using Outlook 43
F Export Outlook contacts by One Category Using Outlook 1
M Cannot change category in inbox; Can change it in popup Using Outlook 0
